Those brakets are for the front seats which I cannot use as my base is different...the base on the recaros is different based on whether you have manual height adjusting seats or electronic...those are designed for the electronic and are easiest because the base just un bolts and then you bolt those on...mine the base does not come off...that is until I grind off the parts I dont need then make my own bracket...
In terms of the rear seats make sure you get Jetta rear seats...mine are from a GTI and are slightly different in size, but would probably still work...I have not played too much with mounting them but if you hang around I will surely get to that
