Supercharged Euro S50B30
  • mck
    • Jan 2007
    • 238
    Its been a work in progress for a while now 2 years approx. But as its finally on the dyno and everything seems to work. Time to post some pics up.
    Old thread started HERE, not much has changed on the exterior, a few interior changes though.
    So decided to paint the engine bay finally after engine conversion was done and completed.
    Basically shit got out of hand and this is the result.
    After engine conversion, wasn’t happy with how it looked compared to the rest of the car.
    So this happened
    Bought these
    The start of a smooth engine bay
    E30 Cab strut reinforcements
    Off to Dr Vanos
    Looks factory
    Throttle bodies stripped, and sandblasted
    Off for powder coating
    Oh Sheeeet!!! its about to get heavy
    Aeromotive fpr
    Rebuilt Z3 short turn rack
    Primed
    Headlights rebuilt
    Before and after
    Parts start to arrive
    shame these are hidden, nice!!!
    Coated
    Fluid cans
    Water to air intercooler in plenum started.
    Back from Dr Vanos, bit of polish and ready to go back on
    Engine going together
    Blower on for the first time
    3rd set of headers, after a few trial and errors
    1 1/3” primary to 2.5” duel mandrel to the end hps coated
    Custom flange out of 12mm steel
    Ready for HPC coating
    Custom Oil cap
    Block off plate
    Engine in
    Custom crank pulley
    -8An for Blower drain
    Back from powder coating
    New steering coupling, fixed solid.
    I revised the blower bracket, it will be 25mm thick, the old one was only 10mm it might have flexed anything over 200rpm. Also wanted to run a separate 8 rib belt for the blower so there’s no slippage.
    Surge tank for the boot, aeromotive A1000 fuel pump, 100micron pre filter, and 10micron after
    In place
    Headers after coating....very happy with the result, just took about 90 hours
    New 25mm master, shorter than e30
    New rear strut top
    New poly gearbox mounts
    Radiator from C&R.
    Modifying to all AN fittings no rubber hose on this engine
    Bits
    Oil cooler and water heat exchanger to go behind front bar
    Custom brake fluid can
    Catch can and power steering res in one
    They reckon these can handle 500hp, will put to test!!
    New blower bracket designed as well as pulleys, off to cnc
    Back from CNC, will paint recessed bit. This thing is rock solid no movement at all!!
    Double bearing pulleys
    Arp fasteners
    BOV and over boost valve
    Accelerator cable bracket new and old
    One way valve for brake booster, new and old
    Plenum finished. Will put rubber boot over silicon hose for factory finish!!
    Engine in and ready for run in tune
    Once I got some figures I will post them up, need to run motor in so might be a while.
    Video, before tune.
    '89' E30 with Euro S50B30
  • craiggroves91
    • Oct 2009
    • 3024
    This thread delivers!
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • 325ix
      • Aug 2009
      • 7783
      You officially win the internet! That is some serious custom building there.
      • amcink
        • 788
        Wow! Just Wow!!!!!
        • 5Toes
          • 9836
          My god... that is a god damned engine
          And this is a god's chariot.
          • Rc 415
            • Jun 2011
            • 723
            Amazing work! Love the end result
            1987 Delphin 325IS
            LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
            Build Thread
            1993 alpine 2 325IC
            •Ground control coilovers•16" BBS RS• momo woodgrain
            • efficient
              • Feb 2012
              • 3312
              Wow so clean
              • eur04lif3
                • Jan 2009
                • 756
                Takes my top 5 best custom build threads :up:
                Drooled all over the customization involved.
                • Killacortes
                  • 1937
                  Fuck
                  r3v does not fuck around. First you get banned, then they shoot you
                  • GT BMW E30
                    • Nov 2008
                    • 2491
                    Show off
                    • Evil-E
                      • Aug 2012
                      • 20
                      When I win the lottery someday I'll build something of this caliber. Hats off to you sir, nice job!
                      • SkiFree
                        • Jun 2011
                        • 2766
                        Just wow.... wow. Never usually post this kind of responce... but wow. Give me a second to comprehend this.
                        ADAMS Autosport
                        • Thrizzle
                          • Aug 2011
                          • 194
                          Holy shit that's filthy
                          Nice work!!!
                          • Eric
                            • 5142
                            dude.
                            • 88SuperETABD
                              • Apr 2009
                              • 911
                              Amazing engineering and designing there...good work. Like the 3d CAD's. I hope to one day meet your standards!!!!
                              Also, you need to either run no hood or a clear hood haha! show that engine off!
                              (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                              1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
