Joey's iS
Also fixed my brake lining light and ABS light. Officially cruising without lights on my dash. EVERYTHING WORKS!
For the brake lining, there is a resistor located within the cluster itself that is located behind the temp gauge (inside the cluster itself) that is the Brake lining resistor. Because the brake lining resistor carries a lot of current, the solder joints inside the cluster tend to crack with age and vibration from the car. All you need to do is reflow the joints, and, as long as your sensors are good and you don't have any shorts, your brake lining light will regain normal functionality.
To demonstrate, here is an extra cluster backing I have sitting around:
The green circle represents where the temp gauge is located.
The red circles demonstrate where the two solder joints need to be re-flowed. As you can tell, the joint in the circle to the right is completely cracked, a common cause of pre-mature Brake Lining light appearing
For the ABS sensor, I saw this write up, and fair enough, when I took my ABS relay out, that little disable link was blown.
So following the essence of the writeup, I wired an external fuse holder found at any AutoParts store for about $3
Instead of wiring the pegs together INSIDE the relay, I mounted the wires and Fuse holder outside of the ABS Relay and drilled holes in the main metal housing to mount it externally. I used a stock 7.5a BMW fuse to top it off, and fair enough, when I first wired in the modified relay, the fuse blew due to a short, proving my system works better than the stock relay. A few modifications to the solders and a new fuse means my ABS light is off, and I am enjoying functioning ABS
A picture before:
And after:
(in ignition)
(after starting)
Oh, and an airbag-bolster-in-a-non-airbag-car-retrofit for the ladies
(+New black sport seats that actually work, fall, and rise)Last edited by JinormusJ; 06-11-2013, 11:52 AM.Comment
Doing an awesome job since picking her up! That car needed a good owner.
Good work JoeyComment
Joey where did you get those Cluster rings? I'm thinking they look nicer than my flush ones
-NICKComment
+1 on DJGenius
Stand up guy, and the originator of the snap-in rings, not the Chinese knock-offs that need glue. Loved em while I had them, but I wanted a more OEM+ "M3" cluster look. I personally felt the rings were over the top for what I wanted, but they are a great product nonetheless
Thanks Daniel! Appreciate it. Finally was able to track down an e34 warning triangle to finish my trunk tool kit from Portland OR. Should be here today.
The little things that matter. Love emComment
awesome updates. Reminds me of the 1st couple yrs doing things one at a time....and on a budget.....then one day woke up and decided to go all out. Still wish I left her unrestored like yours....give the car so much character, blemishes and all
btw i love those cluster rings.www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
'15 Mini Countryman - Blazing Red/Carbon Black
Past:
'01 Audi Allroad - Light Silver/Platinum Saber Black
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*Comment
I love it. As much as I want her fully restored, I enjoy taking it a step at a time and doing this slow, enjoying the car as it is during the process. Sure, she's not the prettiest, but she's mine :up:awesome updates. Reminds me of the 1st couple yrs doing things one at a time....and on a budget.....then one day woke up and decided to go all out. Still wish I left her unrestored like yours....give the car so much character, blemishes and all
And thanks on the cluster rings! I know they're very popular; I sold the 3 extra sets I had in less than a hour!
Shoulda known
You're the reason for half the cool things in his shop as it is
I always thought I would do a full "restore" on my car at one point. But, like you said, I have realized that it is going to be a slower process in which I do something, drive it, do something else, drive some more etc. I think it'll be neat feeling a progression in the drivability and feel of the car with each new step.
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
