***CAtuned E30 Mtech1 Build
Wicked build btw.
Question the manifold that you are running seems to be a monster for the hx35. It has dual 44 waste gate provisions. Is there any particular reason why you went with that manifold as opposed to a manifold with a single wg provision? Obviously the benefits of it being split pulse is great, im just trying to see if there is any added benefits of that particular manifold.
Thanks again.Comment
PM was sent. Let me know if you still dont have it. The reason for the HX35 is the antisurge and our knowledge of the Diesels. These turbo's last for 200K miles and easy to rebuild. And those cummins run 40 pounds of boost for those 200K. The manifold is a work of art and probably more then what the turbo will need. The split pulse is the main reason.Comment
Finally found time to work on this car.
Spayed 3 cans of 3M undercoating. It dries well and another reason to keep this baby rust free for years to come.
Next we started to reinforce the rear shock towers:
After that was done we finished off the 3M spray off:
Next we tackled the coil overs and the Front subframe reinforcements:
One Step Closer- New Fuel filler neck; Fully Rebuilt Rear End (3.73 Differential) with Renewed Finishes Cover; Reinforced rear control arms; AKG reinforcement plates. Steal Braided Brake Lines!
You guys do good work.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
Looking good Igor.
Did you have the erinforcement plates made or are they off the shelf?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
If you have bought items from me, please leave feedback below.
If you are a BUYER, Check My Feedback.:up:
http://www.r3vlimited.com/board/showthread.php?t=183860
Check out my Euro Build Thread
http://www.r3vlimited.com/board/showthread.php?t=215557Comment
