E36 M3 - LS3/TR6060 Swap
  • jakeb
    • 1909
    #151
    Started on the fender flares...
    Start with an e46 sedan after market fender.
    Cut the flare out
    Stock e36...
    With the e46 flare
    difference between the two
    About where it will be...the e46 bit needs to be trimmed down some more.
    Fitment up front
    It will have to blend in here somewhere.
    Some wheel on shots...the FCAB isn't on so I had to hold the wheel a bit.
    Right now with a 15mm spacer the tire is just touching the coil over adjuster. Either have to run a spacer that is just a little thicker or move the spring perch up or down a bit. I would rather go with a little thicker spacer and have full control over the preload on the spring. I will space with some washers first just to see what will be needed.
    This guy wanted to help a little
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • 2e30
      • Jul 2008
      • 277
      #152
      looks great!!!!
      i had tons of fun doing e46 flares on my e36
      my e30 trailer build thread http://www.e30tech.com/forum/showthread.php?t=68391
      TRAILER PROJECT 85% COMPLETE
      SPORTMAXXES CAN LOOK OK
      • jakeb
        • 1909
        #153
        Yours is the one I have been looking at. Very nice!!
        Just showing off the rear tires....
        Awesome to see wheels back on it...
        • 2e30
          • Jul 2008
          • 277
          #154
          damn all beef
          • jakeb
            • 1909
            #155
            Rear flare mock up...
            • jakeb
              • 1909
              #156
              I want the flares to look stock so lots of measuring and planning before cutting.
              I want to keep the edge where the bumper comes to so everything flows like it was stock.
              Front flare at the edge where the bumper will meet. The new flare might get cut slightly higher but it's closer.
              It will match up on the back side under the trim...or right at the top edge
              The top of the new flare still needs to be smoothed out to a nice circle and then the e36 fender will get cut and start welding in the new one. The entire passenger side will get done..front and rear and then repeat on the drivers side.
              • Jezza
                • 222
                #157
                Good shit man, can't wait to see the finished product.
                E-9 Motorsports
                Supported by:
                Insane Innovations LLC
                DTMFiberwerkz
                Achilles Radial
                • jakeb
                  • 1909
                  #158
                  More fitting...
                  Rear...
                  Somewhat setting on the ground...can't go all the way becasue the rear fenders are not cut out so they fit the tire.
                  • jakeb
                    • 1909
                    #159
                    The drivers side flares are mocked up to match the passenger side. Still a little bit of trimming and then they can get cut out and welded.
                    bumper and everything is just setting on and nothing is tightened up. I was trying to get a picture showing how the flares look from the front. Sorta hard to do...
                    Picking up the power coated brake calipers this afternoon and will update when I have them.
                    • BamaE30
                      • 239
                      #160
                      Good work Jake sorry I missed meeting you at the Vintage.
                      Imported from Detroit
                      • pacmanE30
                        • Dec 2010
                        • 1524
                        #161
                        i like your use of flares here, and your work on the headers is amazing. keep it up man, can't wait for the finished product.
                        NRG Quick Release/MOMO Hubs|NRG Limited Edition Deep Dish Wheels|NRG Wood Wheels|Nardi|
                        9five Eyewear|Day of the Dead Tees|
                        WORK Wheels|Lug Nuts|
                        STÄTUS|
                        Got Juice?|
                        • jakeb
                          • 1909
                          #162
                          I should have put something in the photo to show size...they look small on their own but they are far from small.
                          The plan was to use powder to make the ///M but the powder coater did not feel comfortable doing it that way and getting a good results. So they will be done in vinyl. This is the type of vinyl used on signs, trailers, etc so it will handle a lot of abuse.
                          They will get put on once everything is together.
                          Rear
                            • 37834
                            #163
                            Love watching this thread.
                            Grover Beach, California
                            BimmerHeads.com
                            • F34R
                              sLaughter
                              • 12376
                              #164
                              this
                              Instagram: @BWeissLeather
                              Current cars:
                              ~ '87 325 M30B35 swap
                              ~ '87 535
                              ~ 01 540 Msport 6spd
                              ~ '06 X5 4.8is
                              • Galicianslash
                                • Apr 2008
                                • 40
                                #165
                                Really enjoying all the pictures and details, and yeah, do all machines are beasts
