E21 S50 Swap
  • jakeb
    • 1909
    All the suspension parts are going to the coater tomorrow...
    I was waiting for the front calipers to show up so I could trim the backing plates.
    Trunk is starting to fill up with new parts (thanks blunttech)
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • Polaris15
      • Nov 2011
      • 309
      sub'd
      • greg1333
        • Nov 2004
        • 127
        Nice plan...I miss my 323i e21. I had swapped out the 2.3 motor for an late model e30 325i motor... the car was fast, much lighter than an e30.
        Do you have a 6 cylinder front cross member for your swap? or are you going to just do something custom?
        Another hurdle is the speedo input. e21 takes its input from trans. e36 trannys don't have speedo tap that I am aware of.
        Just some food for thought.
        Keep us updated...and best of luck with the build
        • jakeb
          • 1909
          Getting back to progress on this project. Suspension parts back from the powder coater.
          There is also a box of odds and ends but no picture of that.
          • blunttech
            • 12850
            I admire you Jake... I cant seem to finish one project and you juggle multiples at once
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • giantkeeper
              • Aug 2009
              • 1416
              I admire you Jake...you juggle multiples at once
              :nice:
              Always Always go for the reach around if there is an option
              • Galicianslash
                • Apr 2008
                • 40
                i am so sub'd
                • unloadedak
                  • 1197
                  subscribed!
                  2003.5 Imolarot M3: daily
                  1995 Alpinweiß M3: hpde
                  • jakeb
                    • 1909
                    New parts going together. Both of the front struts would have been together but some how one of the $2 strut bearing dust caps walked off.
                    Fresh powder coated strut housings, bilstein sports, and H&R springs
                    Rears...new vs old. Rear shocks were completely dead.
                    • Chriskbmx
                      • Apr 2012
                      • 972
                      as far as doing the speedo for the e21 there are a ton of diff ways to do it. assuming your not going to use the 323i trans I have seen people make the e30 speedo work, have seen people run them off the drive shaft and there are a ton of other ways to do it.
                      • jakeb
                        • 1909
                        It will be either an e30 speedo or an aftermarket speedo run off a drive shaft sensor. I use a after market VDO on my m42 2002 swaps.
                        • jhaurimn
                          • Nov 2012
                          • 2224
                          Wow, looking good so far. I have a friend rebuilding an e21, thankfully his is completely rust free, which is extremelyyyyyyyyyyy rare with e21s. Seems like they all started rusting away before people appreciated them. Not to mention getting parts for an e21 is 9999999999999x more difficult than getting e30 parts.
                          Current:
                          1989 325i
                          1988 M3
                          1987 325ic
                          Past:
                          2001 330ci
                          2001 M3
                          • jharrel
                            • Aug 2012
                            • 130
                            I've been wanting to do this to my e21, can't wait to see the outcome :)
                            • jakeb
                              • 1909
                              Getting things put together.
                              New steering rack bushings...these were a pain to get all put together.
                              old vs new
                              Mounted on the fresh subframe. Tie rods will get replaced once it is up on the lift.
                              Dark pic but on the car.
                              Drivers side
                              Passenger side...waiting on dust seal thing to put the strut all back together.
                              • Lof8
                                • Oct 2006
                                • 2827
                                Jake does the coolest builds. subscribed.
                                S50'd
                                Originally posted by TDE30
                                What is this faggy shit I have happened upon?
                                I can always live in a M3. Can't M3 a house.
