1985 323i m50 nv turbo build
  • 24v323iE30
    • Oct 2013
    • 1
    Basically, I swapped in an m50 into my 1985 323i when the m20 busted the timing chain along with bending two valves. My current goal is to turbo the car as cheaply as possible, I know how that sounds, but im not in great economic conditions. i found an intake mani and im looking for a used t3 turbo, i heard i can run stock internals, as i only want to boost up to around 6 or so psi at most. due to my lack of knowledge in electronic tuning, i would like to avoid megasquirts, vems, etc. is this possible?
  • TheTacoMan
    • Nov 2011
    • 2308
    Oh boy.
    • e30m3s54turbo
      • Jun 2010
      • 3293
      Do you have pics of 323i?
      • acolella76
        • 2950
        lol @ 'megasquirts'
        -Alex
        • MattAvino
          • Jan 2011
          • 2147
          i haz busted car, how can i tarbo cheep?
          i no wanna do the megasquirtz. i dunno how to squirt
          E30 buildy things
          http://www.r3vlimited.com/board/showthread.php?t=195286
          • JCarp90
            • Feb 2011
            • 1759
            • mitchlevy7
              • Aug 2011
              • 672
              You broke the timing chain on an m20? Hmmmmmmmmmm.
              You can get a chip tune or use a miller maf so you dont have to build an ecu. Why did you get an new intake manifold? You need a turbo exhaust manifold,
              Also, cheap and turbocharging dont go together. Most turbo builds you can price out all the parts and multiply it by 1.5 minimum if your doing all the work yourself, more if its your first one.
              Sent from my GT-N8013 using Tapatalk 4
              www.cp-e.com
              1989 Zinno 325i m52 turbo coupe
              2015 Ford Fiesta ST, Daily Driver.
