Ahhh, that's the life I want. Custom Badass engine swaps on classic bmw. Gotta get outa CA, I couldnt drive that e30(or even my own e30) on the streets if I wanted to.
Blunttech / Classic Daily S85 V10 E30 M3 Swap
Had a great time ripping into this for a few days. Unfortunately found some rust I was unaware of. Pretty good sized hole in passenger firewall corner. But Jake assures me he can cut it out and patch it. Other than that hole the rest of the car is better than I expected... After working on Jakes new lift I will be ordering my own soon. So nice to have,....
Looking good! Love seeing this unfold.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
Originally posted by NitroRustlerDriver View Post
Originally posted by jakeb View PostLong time no update but moving ahead now. Steve from Blunttech flew in for a couple days to rip it all apart. On to some pictures....
The 135 brakes fit inside the 17" throwing stars. The 135 rotors are a bit to deep tho. Going to have to look for some different rotors.
I would personally be going with the 345mm CSL discs (for long term supply) with a 13mm spacer, as 17x8" will be perfect.
Example:
Edit: I'm pushing for you guys to do kit because I'm just about to pull the trigger on the 6 piston fronts and twin piston rears and want to run throwing stars :D
Does the 135 caliper bolt straight onto the e30 m3 strut? Does it change the offset needed for the rotor?
Saab 9-3 aero cars have a 314x28mm front disc that has a very similar offset to it that may work with a little machining. They are 45.2 mm high compared to the m3's 40mm.Originally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
Are running M-systems a must? I found with willwood calipers and my old green m-systems, that I had to run a lot of spacer to clear the spokes. I remember running M-systems with 235/40/17 tires on the front of my old e30 M3 and the offset was already a bit tight. If you have to space the wheel away from the 135 caliper as much as I did with the willwoods, I really don't think it will fit unless you run some stupid 195/25/17 tires. Keep the stretch to butt holes only.
Originally posted by Todd Black 88 View PostDoes the 135 caliper bolt straight onto the e30 m3 strut? Does it change the offset needed for the rotor?
Those saab rotors look good but the bolt pattern is not 5x120... Looks like 5x110
any other ideas?www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC
Originally posted by jakeb View PostYes we are finding we need a lower offset rotor than the e46 stuff. The tie rod hits the rotor.
any other ideas?
2010 F650gs twin
Originally posted by Eric View PostAre running M-systems a must? I found with willwood calipers and my old green m-systems, that I had to run a lot of spacer to clear the spokes. I remember running M-systems with 235/40/17 tires on the front of my old e30 M3 and the offset was already a bit tight. If you have to space the wheel away from the 135 caliper as much as I did with the willwoods, I really don't think it will fit unless you run some stupid 195/25/17 tires. Keep the stretch to butt holes only.
