Originally posted by 2002jm
View Post
My euro 320i/B6 3.5 Alpina Tribute ( Now with turbo power)
So I did some stuff today
I also got the e34 exhuast system to mount up so that will be taken off and made in to a full 3 piece exhuast system. I am how ever having troubles with getting moldings and shit to stay on and it's really making me mad cause every time something goes to get her wrong I ruin my paint. I have 4 chips and 1 scratch right now cause my door moldings won't fucking mount to the clips and stay attached to the body. My painter assures he can fix so I hope he can. I assured that if he fixes it a 36 pack will be waiting.
I also got a list of parts to send to blunt.
I'm just pissed beyond words about my paint so I quit for the day before bad things happend.
painter can fix
I am sure the painter can fix the paint....you are using new clips to put the molding on?? The only reason I mention this, is I tried it both ways old and new and the only way to go is new. Crazy old ones just pop back off and then the paint gets scratched in the process.
Wish I had those door moldings:), that is going to be really nice when you shut the doors!
jm
Originally posted by 2002jm View PostI am sure the painter can fix the paint....you are using new clips to put the molding on?? The only reason I mention this, is I tried it both ways old and new and the only way to go is new. Crazy old ones just pop back off and then the paint gets scratched in the process.
jm
My euro 320i/B6 3.5 Turbo Alpina Tribute Now in assembly
Did some work today and some mocking up.
dont worry car doesnt have a gangster lean just angle of the pic
Got my front and rear glass in and out some moldings on.
And fuck these things. I gave up trying to get them in and will put them on sometime or wait until someone offers to do it that knows how
Until then I'm rocking the ugly gap
I'm starting to love this car
That paint looks like you can fall into it..!!
Take your time with the molding clips, I went through the same thing, patience....
The window clips I used a small flat head screw driver very carefully.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Originally posted by Good & Tight View PostThat paint looks like you can fall into it..!!
Yes I figured that out. I would hold my end down and have my dad hold the other and hit the middle it seems to do the trick. For the corners how ever. Nothing is working I just don't get it.
that valence rocks
i'm uh less positive on the spoiler.. does your trunklid already have the holes?
for putting in the corner clips, put them on both ends of the lockstrip (floating above the gasket), then work them in with a small screwdriver, sticking the outside corner into the gasket first and then working the lip of the gasket around.
I think it will look great once the Gurney flap is installed.Originally posted by LJ851kingston is the play by play announcer for this thread.
So the car no longer runs.... I went to start it after putting down pipes on and no dice the starter solenoid doesn't even click over. Battery is charged I have 12 volts at the fire wall terminal but nothing down at the starter or at red wire on the ignition switch. I jumped the solenoid on the starter and it turned over. Also my lights on my dash still light up but i get no power. I did recently swap my dash and it ran prior to the swap, how ever I don't think that has to do with any of it.
Originally posted by kronus View Postred flag right there
