'88 325is M30 street car-->S54 -->S50 -->M54 Enduro Race car
  • Jb325is
    • 2136
    #316
    Found an awesome source for clutches and wear plates, just called to verify prices and they are as shown... Which is really cheap compared to some BMW vendors, and you can choose between 1.9mm, 2.0mm and 2.1mm clutches. AutoAtlanta is also about 1/4 mile from my office!
    I think for now I'm going to buy three new clutches and go with that, don't have the time to do the machining.
    - '88 m54 coupe
    <3
    • LJ851
      • 7918
      #317
      ^Go buy them in person, more than a few people in the porsche world have been burned by AA in various ways.
      Lorin
      The M30 is God's engine.
      • Jb325is
        • 2136
        #318
        Yeah I've heard that, might try the dealer instead if AA tries to make me pay upfront or something
        - '88 m54 coupe
        <3
        • MyE30
          • Sep 2013
          • 326
          #319
          I purchased a few Porsche dog ear plates from ecs tuning a while back for about 37 a piece, iirc.
          This thread keeps getting better and better. Congrats on getting your beast on the road!
          • MyE30
            • Sep 2013
            • 326
            #320
            Also about your loose carrier cover bolts, definitely get some upgraded ones. I bought a set from bimmerdiffs, waited two weeks for them and found out the same 12.9 grade allen bolts are available at lowes.
            • Luke_M
              • Aug 2011
              • 258
              #321
              Just read this whole thread. Very cool stuff.
              If you're interested in making the stock tach read correctly with an 8k face let me know. I've got mine going for about $50.
              Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
              • Tougerunner01
                • Apr 2014
                • 237
                #322
                I just drove an e46 m3 and so jealous you have an s54 in your e30!
                • lagoon
                  • Jul 2005
                  • 636
                  #323
                  Great work. Sub'd!
                  • Jb325is
                    • 2136
                    #324
                    Got the LSD housing cap machined at work today, took off 4MM, which is the thickness of a clutch and wear plate.
                    20141201_154049 by braswell.jonathan, on Flickr
                    After that I picked up the clutches from a Porsche shop around the corner. Unfortunately, they are 2.47mm instead of 1.97mm like e30 clutches. Going to take the difference off of the cover and throw it all together tomorrow.
                    - '88 m54 coupe
                    <3
                    • Jb325is
                      • 2136
                      #325
                      Machined the cover some more, built the LSD and swapped 3.23 gears into my housing. First time I've ever done diff setup and it was not fun, but we got it done. 4 clutches, maybe a tiny bit of extra stack height, should be interesting! The diff is back in the car, just need to button up a few things and re-connect my rear sway bar for autocross this weekend
                      - '88 m54 coupe
                      <3
                      • LJ851
                        • 7918
                        #326
                        awesome
                        Lorin
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #327
                          What did your total preload change end up being? The diff can be unruley if you up it too much...
                          Check Us out on Facebook
                          Full Product Line Tuning
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            #328
                            Doesn't machining just one cover to make up for the extra stack height result in the assembly being off center inside the case?
                            • Jb325is
                              • 2136
                              #329
                              You mean in relation to the stack height in the LSD? If my maths are right we only added ~ .1 mm of stack height. To be honest, I don't really know what I'm doing so I'm just going to drive it and see what happens. I did talk to David and used lots of reference material for set up stuff, so I do feel confident about that. My pinion and carrier pre-loads and backlash are all within spec
                              There is only one carrier cover, stuff isn't really centered in the housing anyways.
                              - '88 m54 coupe
                              <3
                              • tinkerputzer
                                • Jun 2008
                                • 508
                                #330
                                The spacer is taken out of the bottom of the stack as well. Lower right in this pic.
                                https://flic.kr/p/pauWJZ
