Mini-project on the m30s cooling system
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    With summer is getting closer and closer I knew I didn't want to end up in the same situation I did last year, with 1 month before the E30 Picnic and a laundry list of stuff to get done. Not this year, this time I'm getting an early start!
    I'd always had issues running the m30 + A/C on + stop-and-go traffic + 90F ambient temps. The 16" Spal fan just wasn't cutting it for airflow with all the heat coming off the condenser added in. I also knew I had a small coolant leak in the heater core as I could smell coolant with the heat on.
    My first task was to find out just how much fan I could fit on the engine side of the radiator as a puller. Using the excellent drawings that Spal provides on its website, I made a cardboard mockup of several sizes until I finally settled on a curved-blade 10" model. It will fit right in front of the alternator in the upper left-hand corner of the rad which, conveniently, is also where the 16" pusher doesn't have any overlap (meaning that when I'm not moving, that part of the rad is doing 0 cooling).
    Once the fan arrived I was able to test fit it and confirm the clearances. Talk about a tight fit!
    Next up was to mount it permanently. I found a great type of zip-tie at the local Napa auto parts. They're listed as parts for an automatic transmission, not sure why :shrug:
    http://www.napaonline.com/Catalog/Ca...829_0006347894
    Then I had to decide on how I wanted it to be triggered. The 16" pusher is on the 80/88C aux fan switch with a manual override switch in the center console, so I knew I wanted it on the same system. But rather than fork over another $50 for another Spal resistor I decided to only have it run on HIGH and come on at the same time as the other fan. So I ran a new 12V source:
    Wired up a relay I had laying around:
    I tapped in to the stock aux fan wiring for a trigger, and boom! The 16" pusher comes on at medium speed at 80C, and at 88C both fans come on at high speed. Hopefully this will take care of the issue!
    I also had to fix that damn heater core, so I borrowed this sweet Snap-On pressure tester from Austin:
    After hooking it up, pumping it to 16psi and checking for leaks I actually found 4! Only one was in the heater core; the other 3 were around hose clamps and coolant hoses in the engine bay. Time for new hose clamps! 3 clamps later and all is well.
    Time to get in on the heater core:
    I found slightly damp carpet under the core, as the leak was from the end tank and not the core it self, thereby it bypassed the drain system :rage:. After drying the carpet and wrestling the old core out, I popped in the new one and got it all sealed up with new O-rings.
    Turn on car, turn on heat, bleed system, add coolant, verify fan operation, etc etc etc:
    All is well! Between a 2nd fan and patching those small leaks I think the cooling system is ready for just about anything I can throw at it. Now I just need to detail the engine bay, all that filthy dirty shit around the hood hinges and behind the headlights is driving me mad!!!
  • Swanny
    • Mar 2012
    • 2834
    Holy hell that pressure tester is sex. Great idea with wiring in the fans in that fashion, will be coming back to this thread when I get the m20 in for a few ideas.
    Swanny!
    SUCKERS.
      • 37833
      Nice work! I never realized you kept AC with the M30 swap!
      Grover Beach, California
      BimmerHeads.com
      • Bearmw
        • 1323
        I know a guy who runs a Volvo puller fan/shroud that he modified to fit his e34 535i turbo and he has A/C. It didn't look like he had any more room than we do with our E30 swapped cars. It works great for him. No matter what fan setup is used it is critical to eliminate all leaks and air pockets. Your setup looks good but some don't like the mounts that go through the radiator because they may eventually cause a leak. A lot of A/T cars or trucks mount a small transmission cooler attached to the radiator with those nylon mounting tabs.
        • CorvallisBMW
          • 13039
          Well I sure hope they don't rub and end up causing a leak, but time will tell.
          I pulled it out of the garage yesterday and got it all cleaned up:
          It'll need new fluids before the summer high season starts, but other than that she's all good to go.
          • e30m3s54turbo
            • Jun 2010
            • 3293
            I have never seen your ride. It looks awesome with Alpina reps. Thanks on m30 cooling.
            • CorvallisBMW
              • 13039
              Thanks! I did a whole write-up here:
              I have another thread on A/C in M30 swaps too, if you're going that route.
