My Turbo E30 Build!!
  • anorexic_beever
    • Apr 2014
    • 18
    Originally posted by Dj Buttchug
    this thing you speak of. It does not exist really. Good progress so far. Theres some good members in this thread already willing to help you im sure
    You're totally right, I definitely understand. I more meant I used cheap parts to get it to not blow up right away. I feel like I have almost everything to make this a solid little car. I believe that when I get a tune that the afrs and timing will be spot on. I don't rip on it all day everyday, I just cruise
    • TheTacoMan
      • Nov 2011
      • 2308
      Talk to whodwho and get megasquirt, it will make it 10x more drive able.
      I assume you are also running an air filter on the turbo?
      • anorexic_beever
        • Apr 2014
        • 18
        Ha it's already way drivable! And I would if I had the money in hand. But I don't. So I have to make the best with what I got ;) and if I can get it tuned for $100 more, I'm going to do that
        • anorexic_beever
          • Apr 2014
          • 18
          Last night I fixed my oil feed! I got the tee fitting and replaced the sandwich adapter. Works great with no more leaks :) and I got the oil cooler back in. I had a buddy help me and he welded the 90 degree bends from the stock cooler to the shortened straight pieces coming out of the thermostat housing, it was a b-word to get back in be we got it
          • anorexic_beever
            • Apr 2014
            • 18
            Here's the tee fitting. Block and underside of the car are very very nasty
            Here's the oil drain and where it's welded to the pan.
            • ak-
              • 12422
              Good stuff doing it on your own. But everyone here is seriously just looking out for you - stop or don't peg the throttle anymore if you're saying the AFR's are jumping anything higher than 12 on boost.
              1991 325iS turbo
              • anorexic_beever
                • Apr 2014
                • 18
                Thanks man! And I really don't rip it anymore. I can drive it exactly how I drove it before without hitting boost. The tune will come soon! But I do appreciate all the feed back and advise!
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  Why did you move the feed line? The leak could have been fixed with Thread sealant. Also Are you running an air filter?
                  • anorexic_beever
                    • Apr 2014
                    • 18
                    I was using a sandwich adapter between the oil filter and thermostat. The I-mate ring in the adapter was junk and was leaking. So I bought the tee fitting do I could get rid of the adapter. And no, no filter
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      I would run a filter, the hp to be gained without it is pretty negligible. On my car the filter gets dirty quick, I would get one on asap. I also noticed that you don't have a valve cover hose, thats another point that needs to be addressed other wise dirt could get in there as well as shoot alot of oil mist out and be a potential fire hazard. I like that the video inspired you but you are going to quickly learn that this setup wont last without addressing tuning.
                      Edit: Another thing, your oil drain line may cause issues as well Id suggest making it as close to a 90 degree angle as possible.
                      • anorexic_beever
                        • Apr 2014
                        • 18
                        For sure. I just don't have a filter and don't want to buy one. Stupid but oh well. Pcv I'm not worried about. The valve cover has those baffles so oil doesn't come out, and it's always under positive pressure so I don't think dirt is a big worry, but I do get the risk. I plan on putting a filter on it soon. My oil drain is fine? Coming off the turbo it's at 6 o'clock and the drain tube doesn't droop. It's got a nice, close to 90 degree bend in it...?
                        • anorexic_beever
                          • Apr 2014
                          • 18
                          So a little update for the past few weeks.
                          The eBay oil line failed and fried my turbo. I used what I had saved up and go another one and a way better oil line.
                          The afrs have gotten leaner over the past few weeks. Everything started great after the trans am injectors, but just got ever so lean. I pulled the fuel pump out today to check on the hose from the pump to the top hat. Thing was shot. Bloated and was leaking air when I squeezed it. I replaced it with spare -6 push lock and went for a drive.
                          Once the fmu loads up, afrs start at 11 and creep to 12 then drop to 10.6. TCD chip is doing marvelous
                          • anorexic_beever
                            • Apr 2014
                            • 18
                            This is the eBay feed line..
