KI4UJO's 24v Build and M42 DD
  • KI4UJO
    • Jun 2011
    • 642
    Finally, I have actual progress to report. First off, the CPS + DME got it running, but not good. Since the stomp test actually works now, I performed it and got a 1215 (MAF). Popped the intake off to find a mess of dryrotten vac lines, along with one of the ICV hoses completely severed. That would explain basically all of the problems. So, while waiting for the hoses, I started preparing to remove the M10
    During the removal process
    Currently, it is ready to be removed. If it hadn't rained (which preventing me from rolling the donor car outside, as the M50B25 is currently sans intake) I would already have it out. So, tomorrow's goal is to remove the motor, clean the bay, and begin prepping the e30 to accept its new 24v powerplant.
    IMG_0145 by Jonathan Martin, on Flickr
    • KI4UJO
      • Jun 2011
      • 642
      The M10 is out.
      Fortunately, I have a good e36 rack to replace this
      With no motor, my e30 now reminds me of an altered wheelbase drag car.
      Lastly, the boat anchor. It served me well. For my dad, it served as a powerplant for his DD'ing uses form 1994-2000. I put it back into service in 2010. I'm not sure what it's future holds. Whatever it is, it will require a trip to the machine shop.
      • KI4UJO
        • Jun 2011
        • 642
        I fixed the e36. Then, I did with it what e36's were intended to do - donate their drivetrain to an e30.
        Buying this was well worth it. Degreasing this and the bay were much easier tasks.
        My clean m50, brought to you by Super Clean - the prefered degreaser of KI4UJO
        The bay, after being sealed with KBS RustSeal. I'll be spraying it in Delphin Metallic tomorrow (whole car is going back delphin eventually)
        At least the e36 enjoyed its last drive
        Nov. 1991 to July 2014 - May it rest in pieces (it doesn't have much an option)
        Other parts which are going into the e30
        e36 rack (m50 had an oil leak)
        The other e21 recaro
        Various other stuff
        Bay gets sprayed tomorrow, m50 getting dropped in next week.
        • Codym42
          • Mar 2013
          • 611
          Good work man! Keep it up
          '90 325i - 5 speed coupe
          '05 330ci 6MT ZHP
          • KI4UJO
            • Jun 2011
            • 642
            Photo dump time!
            Painted m50 (started swapping the pan today, not shown)
            Current condition of the bay
            e32 V8 Booster
            I decided to add cruise while the dash was out for a hvac box swap.
            I'm happy to see the extra stalk present. It should make long trips easier.
            Onto the replacement heater box
            Prefered electrical tools of this job
            e36 rack
            spacers(yes, the photo sucks)
            Since I want A/C, and decided to go r134 simply because I already have the equipment (I have 609 certification and could do r12, but then I would have to get different gauges and hoses). So, my parallel flow condenser
            Upgraded junkyard fan
            Compared to the original
            New Dryer
            Evap core has been flushed of mineral oil, along with all of the black O-rings being replaced with green HNBR Rings.
            Another item that I added last year was manual windows. I enjoy features such as A/C, but don't feel that power windows are worth the extra equipment. Besides, both motors went out within 3 days of each other.
            I finally lowered it as well.
            Lastly, the completed swap adapter (well, almost. I'll wrap it up once I verify that it works)
            That's it for now.
            • KI4UJO
              • Jun 2011
              • 642
              Ill fill in the details later, but...
              Sent from my Car Phone
              • KI4UJO
                • Jun 2011
                • 642
                Time for the details - finally.
                I intended to have the car finished by the beginning of August. While I could drive the car under its own power on July 31, it had no exhaust and leaked coolant. After fixing the leak and installing an exhaust, it re-entered DD duty.
                However, as with any major project, it had its problems. I had to remove the in-tank fuel pump three times (Walboro 255) due to problems with the rubber flex line which connects the pump to the steel hard line. Also, I learned to hate my loud exhaust and am now running a temporary setup to quiet it down.
                Currently, it is out of commission due to my non-leaking e36 rack deciding to leak. I have a 40k mile e46 ZHP rack waiting to be installed next week.
                Lastly, I'm overhauling the audio system again. While the OEM system was nice, it now shows the fact that it is made of used items. The new components will be
                Kenwood Exceleon KDC-X998
                Planet Audio AC1800.5
                Lukebox (Well, my attempt at building one)\
                Ok, now I'm up to date.
                • Codym42
                  • Mar 2013
                  • 611
                  Nice!
                  Interested to see how the sub box turns out. I'm hoping to make one soon too. I'm planning on doing that with a Rockford Fosgate DVC 8" and that same amp.
                  '05 330ci 6MT ZHP
                  • E30NJ
                    • Aug 2013
                    • 921
                    I like how you are keeping the A/C. Nice work! Keep it up.
                    • KI4UJO
                      • Jun 2011
                      • 642
                      Being in the south, its mandatory. I ran two summers without it, and I'm not doing that again.
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        QFT. All my cars have working AC.
                        Originally posted by kronus
                        • KI4UJO
                          • Jun 2011
                          • 642
                          Well, I received my Planet Audio Amp today... and it had a dead channel. Its replacement should arrive on christmas eve. However, the working channels sounded great!
                          • KI4UJO
                            • Jun 2011
                            • 642
                            Remember that leak free e36 rack?
                            As we established in the last post, that didn't go so well.
                            e36 rack out
                            Its replacement, along with some tie rod ends, brake pads, and a pan gasket (which failed to seal the first time... I don't recommend goteze pan gaskets)
                            This stuff is awesome, wish I knew what it was when I did the pan gasket the first time.
                            Also, I got my replacement amp in
                            The headunit will be in soon. Also, since I got a great deal on the headunit, I also ordered a SiriusXM SXV200. Since I hate FM radio, this should be a nice upgrade.
                            More to come tomorrow - I'll be dropping the motor back in.
                            • KI4UJO
                              • Jun 2011
                              • 642
                              Also, after making the last post, I made this
                              Subwoofer level adjustment built into a dash blank. It is a much better option than the ugly one supplied with the amp, and it only took 5min.
                              • Codym42
                                • Mar 2013
                                • 611
                                How did you make the knob with the blank? I'm sitting here looking at mine right now. I'm guessing u just took the screw out of the back and took it apart, then drill a hole in the blank and reassemble?
                                '05 330ci 6MT ZHP
