Aussie 318is - now S54B32 swap
  • AusScare
    • Jun 2014
    • 220
    #31
    Originally posted by thriftshopclassics
    Have you fixed up the aircon yet? I would love to ask you some questions about it when you do, I am looking at doing the R-134a conversion to mine sometime soon. I have found this thread on e30 tech to be really informative, might help you out too...http://www.e30tech.com/forum/showthread.php?t=113435
    Thanks for the info, I actually have no idea what to do to get the aircon going with the new engine, so going to have to school myself to work out what's going on. I'll take a look at the link and let you know what ends up happening.
    '90 318is
    • AusScare
      • Jun 2014
      • 220
      #32
      Gauge mounting plate arrived today from the group buy, exactly what I'll be needing.
      Any recommendations on gauge types/brands and shops?
      '90 318is
      • AusScare
        • Jun 2014
        • 220
        #33
        Turbo mufflers and catalytic converters - what is recommended?
        There are so many types I have no idea what to get. I need something with single 3" in and out. Not too crazy loud if possible. The cat just needs to flow well - I'll probably get the same brand as the muffler.
        Thoughts/feelings?
        '90 318is
        • kameleon
          • May 2011
          • 288
          #34
          For bolt-on performance exhaust systems and parts like headers, mufflers, cutouts, and catalytic converters, Summit Racing has the lowest prices and widest selection for your car or truck.
          Choose your poison, Cheaper to buy from here plus shipping than buying from here.
          Magna flow cat, Vibrant resonator and Hooker Aero chamber rear muffler is what i use. All purchased fro Summit (using Summit exhaust V-bands too)
          • chrisbmx68
            • 358
            #35
            I am currently working on a nearly identical swap
            sr20 black top
            91 318is
            top mount td06 20g
            chip tune z32 maf
            Porsche 944 brake booster
            venhill universal throttle cable
            braided stainless slave cyl line for a 240sx (fits perfectly in the e30)
            os giken super single
            wiring specialties universal swap harness
            cx racing ebay fmic
            m42 radiator
            spal electric puller fan and oem sr20 fan
            I think I am slightly further ahead of you i just dropped the motor int he other day and will be making the motor mounts soon. Curious to see if we come up with the same solutions.
            Here are some of my pics if you want to see the direction I'm heading. https://www.flickr.com/photos/511702...7648591537758/
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              #36
              Sweet work man, looking forward to more.
              • AusScare
                • Jun 2014
                • 220
                #37
                Originally posted by kameleon
                http://www.summitracing.com/int/sear...rder=Ascending
                Thanks for the link, I'll take a look at what they have. So many options! The Magnaflow stuff looks ok though. Does your cat have a heat shield on it?
                Edit: Thinking this Magnaflow cat and Hooker Maximum Flow muffler:
                Free Shipping - MagnaFlow Universal Spun Catalytic Converters with qualifying orders of $109. Shop Catalytic Converters at Summit Racing.
                Free Shipping - Hooker Maximum Flow Mufflers with qualifying orders of $109. Shop Mufflers at Summit Racing.
                sr20 black top
                91 318is
                top mount td06 20g
                chip tune z32 maf
                cx racing ebay fmic
                m42 radiator
                Awesome! I'll check out your pics. Is the smaller booster just for manifold clearance, or down pipe clearance too?
                Are you going to be using the 944 MC as well?
                I'll take a look at those throttle cables, I haven't thought about what to use there.
                For the clutch slave cylinder, is the e30 one not suitable? I might run a Nismo one for that too then, assuming it's straight swap too...
                '90 318is
                • chrisbmx68
                  • 358
                  #38
                  I Think a stock booster would JUST fit with a top mount manifold which I assume you are using with a turbo that size. Anything bottom mount is super crazy close based on some pictures ive seen of similar swaps. I previously had an m50 swap and was using the 944 booster with stock e30 master for that so I am just leaving it alone.
                  I am planning on using the stock e30 clutch master cylinder with a 3/4 slave cyl http://www.ebay.com/itm/Dorman-Clutc...cea4ff&vxp=mtr
                  From what I gather the bigger the bore the better the feel on the e30 the nismo slave would be perfect but its super pricy. stock is 11/16ths nismo is 13/16ths so I am going to give that 10 dollar 3/4 unit a shot first.
                  In terms of downpipe stuff I am using an AKG aluminum steering coupler to keep the rubber one from melting out and also because I have a manual steering setup. Since we have airbag cars we have more clearance than the early guys so I think all the stock stuff can be retained. There is about an 1/8th inch of clearance between the steering shaft and the frame rail/fuel lines with a 3 inch tube. I will probably go with 2.5 inch just to be safe, you might have to get creative to fit a 3" dp and not melt the fuel lines.
                  this is the clearance im working with, that one fuel line is just dangling loose for the time being.
                  p.s. the bracket for the clutch master hard line is going to have to get removed from the chassis. no need for it anyway since im just using a 30 inch braided line for the clutch stuff.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #39
                    Sick build man cant wait to see this thing shred tires
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • AusScare
                      • Jun 2014
                      • 220
                      #40
                      I'll be building the top mount manifold with the engine in the car, so I'll be able to sort out clearance as I go hopefully. Worst case, get a 944 or Clio booster.
                      Cheers for the link, I'll check that out.
                      Well mine is RHD, so I don't have the steering arm there or anything. It's just a big gap, so thinking the 3" dp should have plenty of room. I'll have to set up a fair bit of heat shielding for the booster and fuel lines though.
                      Also I don't think I have any airbags? Mine is '90 build.
                      Nice, I will copy you then! Where are you getting the braided line from? I need to grab one. Also are you getting a Nissan throttle cable from that site you mentioned? I'm going to be running a Group A commodore throttle, so I'll probably end up having to mess with the standard one I think.
                      '90 318is
                      • chrisbmx68
                        • 358
                        #41
                        disregard half of what I said including slave cyl line stuff I didn't realize you were opposite side drive :( mine is a 91 so my steering stuff is different
                        • AusScare
                          • Jun 2014
                          • 220
                          #42
                          New radiator fan came in the mail. It's a Davies Craig 16" Thermatic 12v, rated at 2120 CFM.
                          http://www.daviescraig.com.au/Therma...6-details.aspx
                          Boost gauge is on the way, and I'm still working out what fittings I need for the oil pressure and water temp gauges.
                          '90 318is
                          • AusScare
                            • Jun 2014
                            • 220
                            #43
                            More bits arrived:
                            • VDO 30psi boost gauge
                            • Intake sensor
                            • Bosch 1150cc injectors
                            '90 318is
                            • ccsdo5
                              • Mar 2013
                              • 708
                              #44
                              This is going to be one serious SR! I was tempted to sr20 swap my 318 before I decided to just turbo the m42. But I love the sound the vvl head makes!!
                              I got to see this car with a vvl head on the sr and it's just gnarly, probably one of my favorite setups.
                              -Dee
                              5-lugged turbo 318is Barn car
                              IG: @deebelmont
                              • AusScare
                                • Jun 2014
                                • 220
                                #45
                                Yeah should sound good hopefully. Also looking for a stroker crank to make it a 2.2-2.3L. The head will also be modified to run on the 'big' cam lobe side all the time, so it'll sound pretty mean on idle, nice and lumpy.
                                Picked up a Turbosmart Race Port 52mm blow off valve for a great price:
                                '90 318is
