Time attack BMW M20 New PB + More Power
  • KrautnotRice
    • Feb 2015
    • 406
    #61
    Very nice build! Car's looking "maaad" :)
    Jealous of that GTX3071... isn't that the new billet wheel series?
    I'm really curious when you hit full boost?
    Was considering a GT / GTX2871 for my M20 for fastest spool up.
    Also, did going from the log manifold to a tubular one increase lag at all?
    Cheers and thanks for sharing!
    '93 300TE 24V Krautbomber
    '84 528e 5 speed Saphirblau Metallic [R.I.P.]
    I love all BMWs with round headlights!
    • jules325i
      • Jul 2011
      • 353
      #62
      Considering I changed turbo at the same time as the manifold its hard to comment on lag and so on.
      I'm on Full boost (16psi) at around 3300-3400rpm.
      I struggled to make over 300 with the log manifold.
      Out on the track the response and power band is amazing.
      329i
      • ahrensNW
        • Mar 2015
        • 1716
        #63
        Subd.
        Hank Ahrens
        1984 Alpine Coupe
        1978 911sc
        • jules325i
          • Jul 2011
          • 353
          #64
          329i
          • Gumby
            • 45
            #65
            Good driving, thing rips hard!
            • jules325i
              • Jul 2011
              • 353
              #66
              Let start with the new video
              (The noise is the tyre touching the flare, we have now solved that issue)
              Heaps of updates!!!
              After the first track day I found I needed to put Power steering back in, it was just way to hard to turn into corners.
              Got a front splitter made up by a Friend.
              Got a big APR-250 Rear Wing to suit BRZ, I'm getting some custom CNC mounts made up so it will be at roof height.
              Had all the exhaust manifold, Dump and screamer pipe ceramic coated to reduced the heat, and look good.
              Had Murray Coote at MCA Suspension Make me some Gold series Coil overs, They make some of the best suspension components in the world.
              Reduced rear sway bar size to 16mm
              Added solid Aluminium rear subframe mounts and diff mount.
              Look at the car now!!!!!
              329i
              • AusScare
                • Jun 2014
                • 220
                #67
                So much awesome, good work on the progress. Why the change to the smaller rear sway bar? What bar are you running up front?
                Sent from my Nexus 6P using Tapatalk
                '90 318is
                • ak-
                  • 12422
                  #68
                  Your build thread, from it's start to it's track debut are what dreams are made of.
                  +1 for using a Hans - that's cool.
                  1991 325iS turbo
                  • jules325i
                    • Jul 2011
                    • 353
                    #69
                    Murray and MCA Suspension did all the calculations When they had the car setting it up and 16mm is the size I need with his spring rates ect.
                    329i
                    • jules325i
                      • Jul 2011
                      • 353
                      #70
                      Thanks its been a dream come true, Yeah i'd be mad not to wear one if you watch that video look at the run off or lack of run off. the track was built in the 1960's with no safety in mind. I hit 230 kmph down that straight.
                      329i
                      • jules325i
                        • Jul 2011
                        • 353
                        #71
                        Am also getting my LSD Rebuilt https://www.difflab.com.au/BMW-188mm...ch-2-Way-45-45
                        And ratio changed to 4.10:1
                        My car sitting next to the MCA Hammerhead World time attack car.
                        MY custom Coil overs made by MCA Suspension, they are truly the best in the bussiness.
                        Front brake hoses are too long so I'm having them remade shorter.
                        329i
                        • sampayne
                          • Apr 2014
                          • 396
                          #72
                          Super clean build! The wing and splitter make that thing look nasty aggressive. :devil:
                          Originally posted by 2mAn
                          The BMW V6 is the best
                          • ccarey3
                            • May 2012
                            • 123
                            #73
                            May have been mentioned earlier in the thread but who makes those carbon fiber door cards?
                            • Mushroom Stew
                              • Dec 2014
                              • 121
                              #74
                              I'd like to know this too. Also subscribed to your youtube channel and hoping to see more race vids soon!
                              • cleanasse30
                                • Jan 2014
                                • 436
                                #75
                                Great build, that looks like an extremely fun car to drive on the track!
                                2.7i Stroker Turbo Build Thread
                                90 325i | 95 Miata
