M30 OEM Turbo project
  • lukeADE335i
    • Apr 2013
    • 1386
    #31
    Great work - the Dietel e21 345i even managed to maintain aircon, so no doubt you'll make it happen too :) There's more width in the e30 engine bay.
    My e30: OEM+ with M30B35
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #32
      Originally posted by kronus
      you can theoretically mod that wastegate to make it adjustable, btw
      I still have all my M106 turbo bits too if you need anything
      what are you doing for management?
      Ya I plan on adding a manual boost controller to help me out there. I might need some bits and pieces like vacuum lines and such, but I think I have all the main pieces. Management will be through my existing Miller MAF/WAR, they actually have a tune for m106 on an m30b35.
      • CorvallisBMW
        • 13039
        #33
        Update time!!
        So you know how I said my garage was tiny? Well I wasn't kidding.
        Very little space on either side
        I've got some room in front to work
        Anyway, on to bigger and better things! First off, time to remove the exhaust. Yes it's very long... I need to have some flanges or v-bands welded on lol
        I hadn't actually dropped the exhaust before, I just had a shop build it on the car. I noticed these pipes are definitely NOT mandrel bent... I'm concerned this could cause some flow issues with the new turbo setup. Thoughts?
        Next up, time to remove the manifolds
        About half of the studs decided to stay behind... time for some double-nut stud removal action.
        With all the exhaust gone, there's actually more room in here than I thought
        Also... I should probably replace my guibo
        Tomorrow I'm taking a big load of parts over to Wishno87's place to sandblast them and get them ready for paint and/or ceramic coating.
        • LJ851
          • 7919
          #34
          If you install your new guibo correctly this time, it will last longer.
          Lorin
          The M30 is God's engine.
          • frankie591
            • Feb 2012
            • 545
            #35
            Yep arrows should always point towards a flange.
            • george graves
              • 19997
              #36
              sub'ed
              Originally posted by Matt-B
              • CorvallisBMW
                • 13039
                #37
                Doh!
                Well I was still young when I did that, I'll chalk it up to inexperience :)
                • TimeMachinE30
                  • Jun 2014
                  • 3749
                  #38
                  Much respect.
                  ACS S3 Build / Dinan 5 E34
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #39
                    Yeah, I like this. Subscribed.
                    Originally posted by Andy.B
                    I was born on 3/25…
                    • indecline
                      • Sep 2007
                      • 244
                      #40
                      Intrigued. Keep it true
                      1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
                      • CorvallisBMW
                        • 13039
                        #41
                        Lets have some updates, mkay?
                        Josh (Wishno87) very generously let me use his sandblasting cabinet on Saturday. Since I plan on either painting or coating most of the components of the turbo system, I really needed to get everything cleaned up before I could get started on that. Obviously paint doesn't stick well to rust or old flaking paint, so sandblasting was by far the best and quickest way to get everything cleaned up.
                        Turbo manifold, exhaust housing, wastegate housing, and oil inlet/outlet fittings:
                        Assorted heat shields and wastgate:
                        Of course sandblasting leaves behind sand (duh), dust and particulate. Again, not good for paint adhesion. I didn't want to wash the steel/iron parts as is would just cause more rust. So my solution was to buy a quart bottle of 91% isopropyl alcohol, pour it in a bag, and use it as a crude parts wash. This way I could easily remove and dust or sand particles from the parts without introducing any new contaminants.
                        Mask everything up:
                        Hang it all on a string, and go to town on it. I used a black BBQ paint rated to 1200F. I realize there are automotive-specific paints out there, but I already had this laying around and I'm sure it will work perfectly fine.
                        Once dry, place on covered pan and bake at 250F for 30 minutes, or until wife starts complaining about the smell
                        Next up: silver header paint (rated to 1500F) for the heat shields and oil lines. I like a bit on contrast in my engine bay, so these should look nice next to the black charge pipes, valve cover, and intake manifold.
                        I also painted the charge pipes in the same black wrinkle-coat (rated to 350F) that I used on my valve cover and intake mani. This wrinkle paint really bleeds, I've never had anything squeek past painters tape like this before.
                        • CorvallisBMW
                          • 13039
                          #42
                          I also had to deal with this little bitch:
                          Drill, baby, drill!
                          Tap that ass:
                          All better!
                          • TimeMachinE30
                            • Jun 2014
                            • 3749
                            #43
                            Cool. Thanks for the update. Don't keep us waiting too long.
                            • kronus
                              • Apr 2008
                              • 13032
                              #44
                              depending on your money/headache exchange ratio, this might be interesting for you: https://www.millerperformancecars.co...stegate-detail
                              cars beep boop
                              • CorvallisBMW
                                • 13039
                                #45
                                That's pretty cool, but the stock wastegate has some cool tricks up it's sleeve for pennies on the dollar: http://www.745i.avulan.eu/
