The car is still inop as it waits for a rebuilt turbo, electronic boost control, and a new wastegate setup. I'm looking at $1500-2k in parts, so I'll be saving up. I refuse to use credit or dip in to savings for a 21-year old hoopty lol
M30 OEM Turbo project
If your turbo failed that quickly you may have an oiling problem. Don't wreck your new rebuilt turbo too. Replace all oil feed lines and fittings.
I rebuilt my k27 and noticed the oil passages had filled up with carbon because the oil cooked inside. You have to rod them out with a dental pick or paperclip, no amount of acid dipping will free it up.
Do you have any of those exhaust/motor mount heatshields left? ^^Last edited by pandaboo911; 01-22-2017, 09:19 PM.
I have good oil flow going in to the turbo; in fact it might be too much. I know that some turbos use restrictors, so I'm wondering if I should look in to doing the same.
The turbo is leaving (hopefully) this week for a rebuild and billet comp wheel upgrade. I'll make sure to let the shop know about the possibly blocked oil passages.
Yes, I do have some heat shields left! Send me a PM.
The turbo is out for repair! Hopefully I get it back in a couple of weeks.
In the mean time, the guy on bf.c who was supposedly making Tial WG adapters for the stock m106 elbow is taking his sweet time. I've been looking at it closely, and I'm very tempted to just make my own. I mean, how hard can it be?
I pulled off the factory WG and started taking measurements so that I can hopefully mock up an adapter for a standard Tial or TurboSmart WG. This is a drawing of the mounting plate and valve for the factory WG.
My goal now is to go find a NIB aftermarket wastegate that I can snag some measurements off of, and see if it's possible to do some cutting and welding and fit an aftermarket WG, sans housing, on to the 4-bolt factory plate using some kind of custom adapter.Last edited by CorvallisBMW; 03-15-2017, 09:28 AM.
Dropped off the entire downpipe/dump tube/merge section of the exhaust today for ceramic coating. Hopefully this helps with underhood temps. Next up: find a PTP turbo blanket that will fit the old K27 exhaust housing: https://www.ptpturboblankets.com/
Also, big shout-out to Gerry and the team at G-Pop Shop. They've been incredibly helpful and responsive, and are a wealth of knowledge. They're also E30 enthusiasts and are working on a very slick variable A/R turbo setup :up:. If you need turbo work, hit them up!
Originally posted by CorvallisBMW View PostIn the mean time, the guy on bf.c who was supposedly making Tial WG adapters for the stock m106 elbow is taking his sweet time. I've been looking at it closely, and I'm very tempted to just make my own. I mean, how hard can it be?
Like this?
Sent from my iPhone using Tapatalk1974.5 Jensen Healey : 2003 330i/5
Originally posted by slammin.e28 View PostLike this?
So an adapter has to be machined to fit an aftermarket diaphragm/valve assembly into the stock elbow.
TCD built like 2 prototypes in 2007 but gave up because the price point was too high.
I did some things today. Picked up my downpipe section from the guys at Finish Line Coatings, who put down 4 layers (2 inside and 2 outside) of their ceramic downpipe formula. Should really help with the underhood temps, and at ~$25 per linear foot it's very affordable compared to some other suppliers.
Next I wrapped the whole thing in DEI Titanium exhaust wrap, just to give it some extra heat holding ability.
It was a little tricky with the 2-1-2 merge of the OEM setup, but I'm happy with the result.
And this beauty arrived in the mail. The heat must be conquered!!
Nice, looking really good. I still need a blanket. The heat shall be conquered.
Sent from my SM-G920V using Tapatalk
'89 535i/5 Holset WH1E turbo
Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
Originally posted by pandaboo911 View PostBummer about the turbo, but that's what happens with non-watercooled turbos. Only way to avoid it is to make sure you install an oil restrictor and run a turbo timer.
Same exact failure on mine, but nothing was damaged beyond the rear bearing.
Hopefully that takes some hear away. When will you be getting the turbo back?
