Brock's Alpine/Cardinal M52 swap
  • ncbrock
    • Nov 2012
    • 172
    Well I picked up a new project, I couldn't stay away from e30s. I had a a alpine on cardinal 86es that I sold probably about 2 years ago, had a few cars in between and I just picked up another alpine on cardinal car (an 88 this time). I bought the car pretty cheap, it had 90% of the m52 swap done, just needed a few odds and ends. The reason it was so cheap is because the m52 that was in it was trash. I thought this was going to be a quick/cheap swap, just throw a $500 m52 in and be good to go, but things aren't looking good with my "new" motor. I just finished my SpecE46 build, so with that project out of the way I decided to get started on this.
    Here is my old es
    Getting it out of the trailer after about 2 months after purchasing it
    in its garage space
    I picked up another m52 that was out of a running car
    here are some shots of the interior
    Well when I was swapping pans to the e34 pan, I found the lower timing guide in 100 pieces in the pan. So I had to disassemble half the engine to get the timing cover off.
    Well since I only had to take the cams out and take off 14 head bolts to do a head gasket I decided to take the head off in preparation for a head gasket.
    and.... this is where I am stuck. This is cylinder #5, looks like coolant was sitting for a while in the bore and ate through the cylinder wall. I think this is beyond what a hone can fix. I'm really not wanting to spend the money on oversized pistons and a bore/all other machine shop work.
    I'm not really sure what to do at this point. I'm glad I caught this though instead of running it because I would have been more mad down the road when it's not running 100%. I might try and get another motor, but it's slim pickings in NC. I found a couple motors in Ohio, and might have to drive up and get those.
  • E30NJ
    • Aug 2013
    • 921
    Sorry to hear that. Since BMW is in South Carolina, don't you think there might me some M52 blocks down there? Nice work, love the cardinal interior.
    • ncbrock
      • Nov 2012
      • 172
      I had a hard time finding the bum new motor, took me about a month of searching until someone finally posted one for sale. I search usually within a 300 mile radius and there is still nothing around even now.
      • ncbrock
        • Nov 2012
        • 172
        Doing little things while I try and find a new motor
        • 318aye
          • Jun 2010
          • 895
          Unrelated, but how did you like the hankooks? I'm in the market for a new set of 15's.
          • ncbrock
            • Nov 2012
            • 172
            Great tire, not really for daily driving though unless you have a lot of money and can replace them often. If you want to daily on them, they are great in the rain and even below 40* where people say summer tires fall off. Just make sure your alignment is 100% spot on including camber, and especially toe, again these tires are expensive. But it's up there for my top 5 track tires.
            • DasTaco
              • Sep 2013
              • 43
              Great start. Sorry to hear about the engine, but that interior is minty!
              • ncbrock
                • Nov 2012
                • 172
                Bought a running donor car. The engine will be nearly free once I take the rest of the car to the scrap yard. The engine runs really smooth, but I still plan to replace some external gaskets and pretty it up.
                • ncbrock
                  • Nov 2012
                  • 172
                  got the engine pulled, now I have to find a way to load this heap onto my trailer and take it to the junk yard
                  • ncbrock
                    • Nov 2012
                    • 172
                    Engine cleaned and painted. Swapping oil pans, putting on new gaskets, and doing vanos tomorrow.
                    modifying the brake booster was fairly easy, but cutting/drilling the firewall to relocate the booster has been a huge pain so far.
                    • mcdougal
                      • Nov 2014
                      • 251
                      What refresh things do you typically do when you swap a motor? I ask because I'm picking up an s52 for my e30 and am not sure what I should do before it goes in. Going to do the cooling stuff but not sure what else should be done.
                      • ncbrock
                        • Nov 2012
                        • 172
                        Oil pan gasket, rear main seal, front main seal, oil filter housing gasket, valve cover gasket, vanos seals, water pump o-ring/new water pump, thermostat and housing gasket. Really if its an unknown motor I would do the head gasket and all the gaskets associated with that too, but since I know this motor was fine I'm going to hold out on that.
                        • mcdougal
                          • Nov 2014
                          • 251
                          Cool man thanks for the advice
                          • ncbrock
                            • Nov 2012
                            • 172
                            Got the oil pan on, rear main seal changed, new water pump, new thermostat and housing, headers on, and OBDI valve cover on. I also put on my rebuilt vanos unit on from my other engine. Class started today though so things might start to slow down, just when things were getting good.
                            • mcdougal
                              • Nov 2014
                              • 251
                              That interior is so rad. I need to find a red interior for myself.
