92 325ic
  • Nate325ic
    • 462
    92 325ic
    Well I'm back in the e30 game for the first time in a decade. Purchased 92 325i Convertible with 122k miles on it. Needs a little bit of rust repair and a suspension overhaul. Not sure what the overall plans are going to be for this car but for now im going to make it safe to drive and enjoy it with the top down when the weather gets better
  • Cabriolet
    • 9620
    from my exp with my verts:
    make sure to only use rubber bushing, HR vert sport springs and koni sports, strut brace.
    check for rust under the battery tray, and behind the rubber under it. i've found rust there on many verts.
    I did a battery conversion to trunk on my car and really like it.
    best speakers you can do are for the fronts are TS-D1320C. rears use TS-D1302R and a luke box with JL 8"s.
    Much wow
    I hate 4 doors
    • fight4life28
      • Apr 2014
      • 821
      Nice Vert,
      • Nate325ic
        • 462
        took a while for an update between ups shipping the suspension to the wrong address and me being on a trip that was supposed to be a week and lasted 3 but I've made some progress. New control arms, tie rods, shocks/struts, sway bar links, and treehouse racing control arm bushings have been installed. Spring and struts/shocks are stock for now while I decide what direction I want to go. There's nothing special about suspension maintenance so the only picture I snapped was my helper who refused to leave me alone while I worked on the vert
        Some how the previous owner snapped the E-brake lever in half so that got replaced, plus new rear center console.
        Before:
        After (still waiting on an E-brake handle) :
        Found out one of the E-brake cables are broken while fixing those items so now thats on the list of fixes. The Car was missing the glove box so bought a replacement
        I was tired of not being able to see at night with the stock sealed beams so replaced them with depo smoked euro headlights with morimoto h1 bixenon projectors. Thanks to glucklich21 for an awesome product
        and installed the painless phantom keyless ignition/entry system. now everything is ran off of a rfid keyfob instead of the key. Only pic I took was of the push button install
        Im waiting for a new non airbag steering column thats sitting at my parents house and once I pick that up I'll be installing a z3 steering rack ive had sitting around, new steering shaft, wilwood pedals and an mtech 2 steering wheel
        • efficient
          • Feb 2012
          • 3312
          lol was the previous owner hulk trying to drift using the e brake
          • Nate325ic
            • 462
            Car used to have a power top but the previous owner removed most of the power bits and did some jerry rigging to make it work
            Exhibit A:
            I removed the rest of it and installed the manual locks, new release cables and door latch
            and for the first time since the previous owner did it wrong the top now goes and and secures safely
            • Nate325ic
              • 462
              Got a fair amount done to the vert the last 3 days. Installed a z3 steering rack, non airbag steering column, sikky steering shaft and started installing wilwood pedals. I still need to plumb the brake lines but have a work trip so it'll be a job for next weekend.
              Old rack beside the new, old rack was completely shot
              removed the dash to get at the column and pedals
              new pedals mounted up
              installed new column and started to put the interior back together'
              steering shaft. alot of room freed up in the engine bay now. I'm entertaining the idea of a ls1 swap and these mods will help if I actually do it
              • TimeMachinE30
                • Jun 2014
                • 3749
                Dang. Not messing around. Looks great.
                ACS S3 Build / Dinan 5 E34
                • Nate325ic
                  • 462
                  Got a little more work done on the vert, started recovering the seats, most of the leather was still good but the rear seat bottom was wrecked
                  had to repair the driver seat frame
                  before:
                  After
                  I still need to do the passenger seat, work trips get in the way of progress for the car but do fund them. I just got back from a trip to australia
                  I also worked on the brakes a little more. Made a plate with bulkhead fittings to go where the brake booster used to be
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    Nice.
                    Where is the seat kit from? Material?
                    • Nate325ic
                      • 462
                      Originally posted by TimeMachinE30
                      Nice.
                      Its leather from leatherseats.com
                      • phenryiv1
                        • Jul 2009
                        • 3246
                        This thread makes me happy. I love seeing another convertible getting proper attention.
                        Patrick Henry
                        • pilotskillse30
                          • Dec 2006
                          • 1957
                          nice work
