Shad0w's First E30 Transformation (M30 Powered)
  • Shad0w
    • Mar 2014
    • 15
    Everyone's journey into the world of the BMW E30 is always a little different, for me the E30 chassis was the hot cougar I lost my automotive virginity to. Prior to undertaking this project my automotive knowledge extended to the mere know how to of an oil change and maybe replacing brake pads on a car or two. Before I ever found this forum or learnt of the versatility that the E30 presents its owners or of the legendary drivability I fell in love with the car.
    So before I ever even saw one in person or even had had the chance to drive one, my search for the perfect E30 had begun, being in the Pacific Northwest the main focus was on a rust free body. As my search began I started to dive into this forum absorbing as much information as humanly possible. I quickly changed my focus to approaching this chassis with the opportunity to teach myself everything I could ever want to know about the inner workings of a car from a complete engine swap and reseal to body work and a fresh paint job.
    ***DISCLAIMER: All photos were shot with an iPhone, I know its a shame that the picture quality suffers but this isn't an art gallery. And also Ive done my best to take as many photos as possible but I have a habit of getting to work and forgetting to take an pictures****
    My search stretched for 5 long months looking at many E30s in my region however none were up to my standard of rust free (rust repair was one aspect I was not looking to tackle). After these months of longing for an E30 I had finally found a 1987 BMW 325e coupe in luxorbeige metallic just 2 hours away from home.
    The car ran great, got awesome fuel economy, gave me little to know issues ever and I drove it like this for 2 months getting a feel of the fantastic driving experience that the E30 gives. It was then that I decided I wanted more power. Thus time to apply all the knowledge that R3V has given me over the past months, I considered a M52 swap for a few weeks but a few local BMW guys convinced me that I in fact wanted to experience the torque monster the the M30B35 is. I enjoyed the idea of the period correct feel of it, it looks very similar to the M20 however drives like a bat out of hell.
    After a trip to the local yard I felt I had struck gold finding a 1989 735i mated to a factory numbers matching 5 speed with just 160,000KMS, I was estatic knowing how rare it was to find a factory 5 speed in an E32.
    Well lets just say it wasn't the healthiest M30 I'd ever seen
    And as the head showed the extent of the wear was not only limited to the head, once I pulled the head I came to find out that the block had crack in 5 locations between coolant channels and head bolts, all similar to the picture below
    I talked to the yard I had got the 735i engine from and they respected that fact that it was damaged and miraculously gave me a complete replacement engine out of a 1992 535i auto with 189,000KMS free of charge.
    This engine was in much better shape
    Only visible issue found of this bit of wear on the camshaft lobe of cylinder 5
    Pulled the head
    Appeared to the original head gasket
    The tear of the gasket near the timing case occurred during removal
    The factory cross hatching was still plenty visible on all cylinders
    Upon tear down came time to order all new gaskets and seals for everything on the engine and the 3 main seals on the transmission. HUGE thank you to Steve at Blunttech, he set me straight on what I needed for completely resealing this engine, he couldn't of been more helpful with my million questions, THANKS Steve.
    After many hours of wire wheeling the block I had given myself a clean engine block to throw some high temp paint on (I know the gold is little flashy but you can hardly see it when the engines installed and helps immensely for spotting leaks)
    I sent me intake manifold and valve cover to a local guy for sandblasting and powder coating and the pieces couldn't of come out any better
    Engine back together with all new gaskets, (I don't know how everyone manages to get photos of every step, so with me you see the final product)
    As well as a new OEM clutch from Sachs
    Then came time to pull the old M20, being the first time ever pulling an engine and the first my dad had done it in 30 years it all went surprisingly smooth, the old lump
    An empty bay
    Get the bay clean
    New parts are always happy days, the rad that will be working overtime to keep this beast cool, Ive heard mixed reviews on Mishimotos but I look forward to a first had experience
    And a SPAL pusher fan to help in traffic, this fan was a puller which was not what I needed but big thanks to CATuned for sorting out this mistake and swapping for a pusher, great staff!!
    Prior to being able to toss the new engine in I had to deal with the 1% of rust that the entire car had, right where the firewall and inner fender met,
    I had my buddy come over and weld it up with a crappy welding setup we borrowed but for our purposes it worked just fine
    I purchased my mounts from F34R one of the moderators on here and one of my many inspirations for this entire build and then in went the engine after a little bit of firewall massaging
    Let just say clearance was tight with where the engine is mounted I have about an eighth of an inch between distributor cap and rad
    Doing a valve job to quiet the valves, and man what a fussy job, its not perfect as it was my first time doing one but sure helped
    The final product
    Off to the local exhaust shop as an open manifold M30 is much to loud at idle even to drive 10km, hopefully she isn't on a flatbed again for a long time
    The M30 has now been running on the street for a week and Im having an odd issue, the M30 is running too COLD, weird I know, the tempt has sits around 1/4 on my gauge and even drops to the edge of the blue when cruising late night on the highway, and thats only in like 0 degree celsius weather, not that cold.
    If anyone could shed some light on this that would be greatly appreciated??
    Next up, Suspension:
    For this department I turned to the guys at Ground Control, this car soon to be my daily driver I was focused on function over form and I knew I wanted an aggressive street car. On Black Friday I purchased Ground Control's Complete E30 kit with 440# fronts and 650# rears, I felt this would achieve the ability to throw the car into the corner as well as a decent ride height so I didn't have 4x4 status.
    I turned to my local welder to section out 2" and TIG weld the strut housings. Looking back I wish I had only sectioned out 1" possibly 1.5" but either way you roll with it and this is what I achieved
    And the ride height with the rear adjusters all the way up and the front almost at the highest ride height
    Along the way I also dropped the rear subframe and paint the subframe and installed Condor Speed Shop subframe bushings and diff spacers as well as trailing arm bushings, I will have to get pictures later as I forgot to take any during the process, boy what a job. The car also has Condor Speed Shop motor mounts, trans mounts, offset CAB bushings.
    The photo above is how the car sits as of today, next up exterior cosmetics time.
    Plans:
    Plastic Bumpers
    Style 32s
    A complete tear down of the car and respray of Luxorbeige Metallic
    E36 Steering Rack
    Short Shifter
    Skid Plate
    And then… interior
    Hoping the exterior is done by Bimmerfest to have a respectable car to take on the 1200 mile journey
    Until next time, Ian
  • theDELO
    • Nov 2014
    • 37
    Nice work dude, looks great. No audio of the newly built exhaust??
    • ttrousdell
      • Nov 2009
      • 1770
      Looks just like f34r's engine bay. You will like the m30. I loved it when i did that swap.
      The Build:
      • lambo
        Captain Scene Points
        • 10953
        Very nice! Looks a lot like F34R's E30.
        • Matt341
          • Feb 2014
          • 374
          Good stuff going on here love the car
          Bmw CCA # 490080
          1995 525iA RIP
          1987 325e Cirrusblau-Metallic/Pacific Blue (Sold)
          1986 325es Schwarz/Schwarz (OEM+ Build)
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            great work dude
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • F34R
              sLaughter
              • 12376
              Glad to have inspired your build and provided you with mounts :D
              Loving the color of the cover and manifold, looks a little lighter in color than what I have, glad you went that route! Luxorbeige FTW
              He messaged me about going the same route for his bay, I had zero issues with it :D
              Two door version, now he just needs some ratrod flavor ;) jk, the car looks really good, stoked to see it once he gets a bunch more work done.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
                • 37829
                Looking good! Nice work so far. I'm loving the colors.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • pandaboo911
                  • 2070
                  M30s are such sexy engines.
                  • Shad0w
                    • Mar 2014
                    • 15
                    Thanks for the kind words guys, Im pretty stoked on the outcome, the bronze in the engine bay just looks to perfect and really digging having the exterior sleeper feel to it currently.
                    Ill post an exhaust video soon, custom downpipes to y-pipe to 3 inch to a muffler, its pretty freaking loud I'm sure a resonator will be in my future haha
                    • Shad0w
                      • Mar 2014
                      • 15
                      Got a few more things tidied up, got around to install my SPAL pusher fan with 3 custom brackets out of aluminum which make for easy removal
                      riveted to the rad support for a clean finish
                      Cleaned up the wiring harness with plastic tubing
                      Also the fan switch I bought turned out to be the wrong switch and turns on at 92* (pn: 61-31-1-364-272) when I wanted one that turns on at 82* (pn: 61-31-1-364-272-82) it was the parts guys error when ordering it for me so warning for anyone in the future!!!
                      Got a new oxygen sensor which has seemed to fix my issue of running rich
                      Managed to get my temporary intake setup replaced with a much more permanent solution
                      bought a 3" coupler married with a 3" 90* elbow to get the filter to roughly where I'd like it directly behind the headlights
                      And am happy to say I took the old girl for her first road trip and she handled the 560mile the trip like a champ, I managed to get 27mpg with the stock 2.93 diff cruising at 78mph (125kph). One grief the car gave me was a weird occurrence it happened once on my way to my destination and once on my way home, after cruising in 5th for over and hour and a half each time when it came time to downshift for an exit ramp the trans wouldn't go into gear. It wasn't a shift linkage issue and it seemed to fix itself after the car sitting with its engine off for 10 minutes. So this is super weird and has only happened to me these two times since the month of M30 fun. If any one could share some wisdom on this Im all ears!!
                      Cheers, Ian
                      • marshallnoise
                        • Sep 2013
                        • 3148
                        Great work man. One day I'll be in the same spot as you. Is the car a hoot to drive even with the 2.93?
                        Si vis pacem, para bellum.
                        New Hawtness: 1995 540i/6 Claptrap
                        Defunct too: Cirrusblau m30 Project
                        Defunct (sold): Alta Vista
                        79 Bronco SHTF Build
                        • AwakenNoMore
                          • Dec 2010
                          • 1291
                          Fantastic build! This is coming along nicely.
                          1991 325i - "Scambles" The Daily Driven lightly modded.
                          1988 Mazda RX-7 TII "Mako" The Free Dorito
                          bacon by Jared Laabs, on Flickr
                          • Mickler
                            • Jan 2016
                            • 1
                            Paint
                            What was the brand of high temp gold paint you used on the motor, cause it looks amazing.
                            • F34R
                              sLaughter
                              • 12376
                              Looks great!
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
