'91 318is Crack Pipe Edition
  • beta14ok
    • 283
    #46
    ^ Golly, that's coming along nicely!
    • MusikAffe57
      • Mar 2012
      • 84
      #47
      OEM Carpet install
      Installed the carpet today with my wife. I was able to pull the cut piece from the old carpet out from under the HVAC box. The carpet came with the HVAC area perforated so I went ahead and took it out. The rain coming in forces us to stop there.
      1991 318is ....... 1985 320i
      1974 R90/6 ...... 2006 Prius
      318is Crack Pipe Edition: Thread
      • MusikAffe57
        • Mar 2012
        • 84
        #48
        Thanks!
        • ttrousdell
          • Nov 2009
          • 1770
          #49
          Coming together nicely. Keep the updates coming.
          The Build:
          • MusikAffe57
            • Mar 2012
            • 84
            #50
            Interior put together
            Got most of the interior back in. Needs headliner and grounding nut for fuel. I have some leather for a steering wheel wrap and eboot. Duct taped driver's side bolster for now. It kept scratching me while getting in and out.
            fixed the tach, too. That's not idle. I just gave it a little gas for the photo.
            • MusikAffe57
              • Mar 2012
              • 84
              #51
              Euro plate filler
              Found a euro plate filler for super cheap off of ebay the other day. still need to cover bottom holes.
              Early model plate filler:
              51-13-1-888-450 Euro
              51-13-1-888-463 US
              Late Model plate fillers:
              51-13-1-961-241 Euro
              51-13-1-961-242 US
              popped out the plug in nuts
              Mark holes
              3/4" drill bit
              Installed
              • MusikAffe57
                • Mar 2012
                • 84
                #52
                Fixed cluster board
                When the reverse lights shorted fuse #21, it blew out a portion of the board on the instrument cluster. I soldered in a new wire to replace the burnt out portion, and then checked the surrounding connections with a continuity test to make sure nothing is connected that shouldn't be. Finished it off with some electrical tape to insure that it doesn't move.
                Haven't had time to work on the e30 much this fall semester.
                • MusikAffe57
                  • Mar 2012
                  • 84
                  #53
                  Blower Motor Replacement
                  Finally getting around to replacing the blower motor. Parts on order. I took out the blower first to confirm part. I hooked it up to a 12v battery and it barely spun. The fans are difficult to spin by hand. It didn't work on any setting on the switch, and would blow fuse #20 anytime I tried setting four. If it works on setting four, then it might only be the resistor located directly below the blower. Resistor is new. Also, I was able to easily remove the retaining clip by hooking a coat hanger under the clip end and it came right off. The fan is damaged on the passenger side. The plastic housing behind the blower had been chewed through by the fan. When I mount the new one in I'll make sure to check that it isn't rubbing or won't move around. I'm not sure why the fan would've eaten through the plastic housing in the back with it strapped in.
                  Blower part numbers
                  64 11 1 370 930 - Aluminum inlet, 5" fan diameter (Fat and Stubby)
                  64 11 1 466 015 - Plastic inlet, 4" fan diameter (Slim and long)
                  I had the aluminum heater core inlet, so I ordered "64 11 1 370 930 - Aluminum inlet, 5" fan diameter (Fat and Stubby)" from RMEuropean.
                  I used these 1991 318is specific instructions from m42club to move the wiring on the firewall out of my way.
                  http://www.m42club.com/forum/index.php?topic=2912.0
                  • MusikAffe57
                    • Mar 2012
                    • 84
                    #54
                    Instrument Cluster Grounding Nuts
                    I had been missing my fuel gauge grounding nut since I bought the car. I looked through my hardware and came across the #8 Hex nut and split washer from a harbor freight kit. It fit so now I know how much fuel I have.
                    Got my interior put back together except the steering wheel, which is still waiting to be wrapped. Might get to it this week.
                    • Bmwdayz
                      • Apr 2011
                      • 609
                      #55
                      Coming along nicely! Love the carpet as well but I don't think I could get myself to pay that much!
                      • MusikAffe57
                        • Mar 2012
                        • 84
                        #56
                        Thanks. Yeah, it's a tough pill to swallow, but to me the interior is more important than the exterior. My last e30 was beat to death on the outside, but mint on the inside.
                        • 88SuperETABD
                          • Apr 2009
                          • 911
                          #57
                          New carpet :) Nice...Looks like your tackling everything! Keep up the good work and attention to detail!
                          Turning that 1k car into gold :)
                          (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                          1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
                          • MusikAffe57
                            • Mar 2012
                            • 84
                            #58
                            It's Snowing!
                            I present the snow30. Poor thing was on the LA scene and probably never seen snow. one car garage probs.
                            • MusikAffe57
                              • Mar 2012
                              • 84
                              #59
                              Got the blower installed after three days of snow... The resistor is out. It only works on setting 4. Looked new, but I guess you can't tell by looking.
                              • Ocell
                                • Apr 2013
                                • 291
                                #60
                                This is great... quite the resurrection. Subscribed!
                                91 318is Members' Rides Thread
