Lira (euro DS mtech II 318is reshelled, 24v swapped, also now BAR'd)
  • kronus
    • Apr 2008
    • 13027
    update: fuck installing these things
    cars beep boop
    • kronus
      • Apr 2008
      • 13027
      double update: fuck sunroofs
      flimsy fiddly pieces of shit
      anyway headliner's in and quarters are in and rear seat is in
      this panel is being a little shit and breaking the clips that hold it to the rail it slides on. until I can get new ones, sunroof can't go in. (pn 54121934933)
      tomorrow, windshields and seats and dash and maybe even doors
      cars beep boop
      • JonTheHero22
        • Apr 2014
        • 114
        It's looking good man. Keep rolling with the punches, it's annoying but so worth it at the end. You're gonna have a sick MT2 coupe
        • kronus
          • Apr 2008
          • 13027
          well, today was a day
          first I took the dash and carpet out of the receiver
          nice and tidy, how it should be.
          then I took the donor apart some more..
          the passenger footwell is just thoroughly fucked through with rust. good thing this shell isn't going back on the road!
          some more goodies pulled out of the italian car..
          Hella smileys
          this was a pleasant surprise!
          euro foglight switch
          mtech II wheel
          Italian OBC!
          and a euro cluster..
          anyway, then I got to assembling it...
          first, re-foam the HVAC flange
          then stick the carpet in (I cut around the HVAC because fuck that noise)
          and then I got focused and didn't take photos until the interior was mostly together
          also while taking the dash out, I found this:
          the car shall be called Lira.
          cars beep boop
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            Jealous of all the euro parts. Trying to decide if I want to put in a euro obc or a euro clock in mine
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • robrez
              • Jul 2008
              • 3376
              Very awesome! Are you going to use the euro front fenders with side repeaters?
              January 2012 COTM
              • kronus
                • Apr 2008
                • 13027
                Clock! Clocks are rad.
                I'm going to transfer the repeaters and cladding to the fenders that came on Lira, they're straight and have new paint.
                cars beep boop
                • kronus
                  • Apr 2008
                  • 13027
                  Got a few more things done: hung doors, installed lockstrips, buttoned up interior, painted under-headlight strip of valence.
                  I used a paintscratch can for the valence and it came out well. 3 medium-light coats, 1 dust coat (the can says to do this to make the metallic look right), 2 coats of clear, still needs to be wet sanded and a final coat applied.
                  Also pulled this out of the donor, it's a bit absurd. Anyone want a nice old school pioneer setup?
                  cars beep boop
                  • rzerob
                    • Jun 2013
                    • 2315
                    Subscribed.
                    • kronus
                      • Apr 2008
                      • 13027
                      I'm not sure what to do about the transmission that's going to be in this car.
                      On one hand, I have a Getrag 250, the selector rod it likes, a brace for it, and a driveshaft that will bolt right up between it and a S3.46 diff.
                      On the other hand, I have a Getrag 245/11, the selector rod it likes, a brace for it, and a driveshaft that will bolt right up between it and a S3.46 diff.
                      "They" say the 250 is known to be a weak transmission, but "they" say much the same of the 245. Doglegs are cool..
                      cars beep boop
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        Awesome, sub'd
                        • LJ851
                          • 7918
                          Unless that dogleg is really worn out, it will last a long time behind that engine.
                          I vote dogleg for euro cool factor.
                          Lorin
                          The M30 is God's engine.
                          • rcsoundn1
                            • Nov 2012
                            • 3361
                            Nice project, and great progress. PM me about the old audio stuff with a price.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              Dogleg with out a doubt.
                              • vitiokas95
                                • Dec 2013
                                • 482
                                very nice
                                1990 e30 325is S50 swap (NASA GTS2 race car)
                                1990 e30 325is
                                1988 e30 M3 S50 euro swap
