86' Widebody Eta Track Car Build
So you're that guy.......I have a fund set aside for the same kit.sigpic
Instagram @rebellionforgeComment
my only complaint is I wish the arches were taller.sigpic
If you are going for the ultra wide, I would wait a little. He might be coming out with a solid quarter panel with the flares molded in. I ended up buying the m3 quarters separately and will have to mold the flares into it. Another issues is that the diameter of the rear flares don't match the diameter of the fronts. Not a big deal, just more glass work.Track Car Build:http://www.r3vlimited.com/board/showthread.php?t=365614Comment
I just wish the arches rolled closer to the hood line. We'll see how things go. I'm far from doing anything with the body to this extent anyways.sigpic
O, now I get what youre saying and I totally agree
Got some things done last night. Finished up the diagonal bracing on the rear down tubes as well as re-notched the main hoop diagonal.
IMG_20150907_092636 by Chris Mui, on Flickr
Im a big fan of nodes
IMG_20150907_092711 by Chris Mui, on Flickr
Also gutted both doors and was able to get the driver side door bars done. It doesnt look like much but for some reason this took FOREVER to get the right angles and the right notches.
IMG_20150907_092619 by Chris Mui, on Flickr
If you are wondering, yes the top bar is slightly in more torwards the driver as it follow the contour of the driver door really tight.Last edited by thestein1016; 09-07-2015, 10:19 AM.Track Car Build:http://www.r3vlimited.com/board/showthread.php?t=365614Comment
Bumper brackets
IMG_20150724_171905 by Chris Mui, on Flickr
IMG_20150724_173725 by Chris Mui, on Flickr
IMG_20150725_093238 by Chris Mui, on Flickr
IMG_20150725_093527 by Chris Mui, on Flickr
IMG_20150725_102306 by Chris Mui, on Flickr
Rear bumper mounted. Based on the shape of the rear bumper Im expecting just shy of 2 inches wider than stock not including the additional width of the flares. Overall, maybe 3.5-4in wider each side.
IMG_20150907_092751 by Chris Mui, on Flickr
judging by the work ive seen so far, this is going to be one clean e30.Comment
