My '88 Lachssilber s52 e30 Build
  • ZRhett1
    • Dec 2014
    • 17
    One year after I bought it, my e30 lives again. This time, with a newer and healthier heart. My car started as a neglected, ticking 325is and is slowly becoming something I can enjoy on the road and (soon) track.
    When I picked it up:
    The worst and, luckily, only rust spot:
    What the interior looked like when I bought it... It was a lot worse than it looks. Those seat covers were nasty and the interior smelled like fish (literally):
    It had a blown head gasket. Thought getting the head redone would fix it... It did not. It turns out more was wrong with the engine. It ticked loudly and I didn't feel like investigating further as school was approaching. Maybe now it was time for a new engine.
    It sat for ~8 months while I finished school & traveled during the summer. Beginning in August 2015, things started getting fun. And expensive. I was finally ready to fix it. I was looking at m52s with Tippey764 when he came across someone selling an s52 for $1,000 posted only 30 minutes prior. Needless to say I bought it the next day.
    Uh oh:
    Easiest way to swap an engine:
    Bye:
    Out with the old and in with the new ('98 e36 m3 rack):
    DIY Hurst Shifter:
    A few months after the process started, and all thanks to my good friend Tippey764, I had a running, driving e30.
    Ooh, Shiny (fancy photo cred to Tippey764):
    How it sits now:
    More to come! I'm just getting started.
    Future To-Do's:
    • e30 m3 springs + swaybars powder-coated and installed (with Bilstein Touring struts for now)
    • iS lip & plastic bumpers color-matched and installed
    • Fix random power drain from the K4 Relay (low beams)
    • Fix interior lighting
    • Rewire window switches (one is backwards...)
    • 15x8 4-lug Wheels & 225/45r15 Tires
    • Big Brake Kit (To go with my e32 MC & 944 Booster)
    • The list goes on...
    1988 325is Lachssilber s52
  • Reichart12
    • Aug 2012
    • 2165
    Another Maryland lachs car! Where about are you from?
    Instagram: Reichart12
    • ZRhett1
      • Dec 2014
      • 17
      I'm up in Frederick, but you'll find me all along the 270 corridor
      • ZRhett1
        • Dec 2014
        • 17
        Car was leaking like a sieve after the swap:
        Turns out something wasn't tightened properly, causing oil to leak. Trans was leaking because my reverse light plug disintegrated. Power steering fluid was leaking because ¯\_(ツ)_/¯
        All leaks were fixed in a few hours.
        Also - finally have my e30 m3 springs powdercoated! Most likely these will go on over the weekend or sometime next week.
        I have the swaybars too, but I need a new front subframe to install them. The tab is completely rusted off.
        I also seem to be having an issue with my clutch - it never completely disengages. We've tried bleeding it several times, but it has only made the problem worse. My friend's going to replace the slave cylinder to see if that fixes things. Any other thoughts?
