Mila, the Australian 325is
  • mila325
    • Sep 2015
    • 82
    Hey guys, so I've lurked the r3vlimited forums for about a year or so now, and have to say that this is an abundance of information that has constantly helped me out with my E30s. Just making a little project thread for my 325is, and hope that you enjoy and can perhaps learn/add to my build!
    A little backstory (you can skip this) I became infatuated with the E30 back in high school, from stanced out builds to all out race cars I always loved it. Something made me so happy every time I saw the gorgeous front end of an E30.
    I persuaded my parents to get me a 318is for my first car, however this didn't last too long and I crashed it within 3/4 months of having my provisional license.
    After this, I was carless for a little. Then a supposedly great deal popped up. A 325is, that just needed a little TLC to be absolutely mint. For 8k, a 325is with a complete M-tech 2 kit + all the other iS goodies was a great score. Being a little reckless, went and saw it and bought it on the spot. This was a mechanically a great car, but underneath not so much... Here's some photos from how it looked when I got it.
    Around a few weeks later I delved deeper into the car, and uncovered some nasty truths that I didn't like at all. It had some major rust issues, the paint was rather faded and the clear coat burnt through in some spots, the body kit didn't quite fit right and I was in for a lot more.
    The valence was completely ruined to fit in a fibreglass copy of the M-tech 2 front apron, and the bumper was also a fibreglass piece, that didn't fit well, at all. The apron was also rather rusted as the PO had simply just tec scrwed it into the valence. Yet, still, I was bound to find more. It had also previously been in a crash, as there was a new core support that was a different colour (blue/purple) and it was kinda bent around that area. I fought on, and found that under the bootlid there was quite a nasty amount of rust, which when wire wheeled revealed some big holes :(
    I grew tired of the fully hectic drift spec wheels and decided that I would go ahead and get some BBS RS that would suit the car just a smidgen better.
    I was rather satisfied with how she sat, and was going along quite happily. Around a year ago now, I lost my license doing a silly speed. Got it back the same day as I lost it through an agreement that cost me a few dollars.
    During the next period I saw a $600 318i auto for sale, this turned out to be the most fun I've had owning an E30 as I didn't care about it. This car (Cranberry) was taken on a road trip roughly 3000km there and back, whilst also putting my girlfriend (Heather) and I around for 3 months in nearly always below negative conditions. Heather has grown especially attached to Cranberry.
    ... nearly completely forgetting her other purchase, a perfectly kept 323i manual.
    (I'll add more photos of this later, we named her Violet)
    Up until this point, I hadn't really done much to the car beyond basic servicing. Just this weekend I decided to go ahead and make my core support removable in anticipation for engine work that will be conducted soon.
    At this point, I discovered that the door pods and the side skirt were also attached rather sadly. Tec screws and silicon.
    There were also random holes drilled into the body for no reason. I'll have to see what to do, I may just get rid of the kit, I don't like it anymore.. Continuing with the radiator support
    I can write it up in more detail if people want, but it's rather simple. Everything bolted back up true, just need to get the bonnet aligned as my friend had to leave.
    So that's where Mila is at currently, got a whole bunch of work planned and parts on the way, will update this when I get the time! Thanks. :D
  • mila325
    • Sep 2015
    • 82
    Haven't been upto much, currently we're having a little space war with my dad and the garage. He's not too happy with me running a muck, so that's why in a month or so we will be in possession of a 200sqm shed where I can run my antics all day and night without issue.
    What I have done has been rather uninteresting, I removed the rest of the M-Tech 2 kit and have stored that away (read: in the car, as well as the rest of the interior I've removed).
    - I've removed all the tar from the trunk, rear seat, and the front foot wells. Getting dry ice in Australia is a little hard, and to be honest I was too lazy to drive and get it. I used a heat gun + scraper to remove the tar itself and that was easy as. For the residue it left, I used a commercial grade glue remover that painted on and removed it instantly. I now have nice clean floor pans!
    Excuse the mess, I was wire brushing all of the surface rust trying to find where I actually had to cut out and weld in new metal. Fortunately, there is no penetration or rust at all on the passenger side, the drivers side is a different story...
    In the photo above, you can also see the absolute mess of an alarm system that the PO had installed, it was a mess, and it's shitty install resulted in the use of the indicator stalk, regardless of direction, turning on the hazard lights. Taking out the alarm + the remote locking removed this problem, but I have no idea how he had messed it up before...
    The worst of the rust is near the base of the accelerator pedal, however, I fear that it's also under the rocker panel and means a fair bit of metal needs to be cut out and welded in (which is no problem), does anyone know what I should use to seal up the fresh welds once they've been ground down?
    Here's the base of the accelerator pedal, straight to the ground... it's messed up, and I'm too busy to go get a donor mount, so i'll see what I can do about making my own. It shouldn't be too difficult to make, I'll try document it the best I can.
    I've also been doing a little routine maintenance as my parts came in from Pelican (great service, never had a problem with them). Replaced my distributor + rotor with new Bremi units, aswell as my spark plug leads and the fuel filter. Still having a rich running issue, need to sort that out. New O2 sensor didn't fix it and I've also checked the ECU coolant temperature sensor and the resistance was spot on at the sensor and the ECU so don't know what gives...
    Well, that's all for the last week or so, as I said, having troubles with space at the moment but will be getting more soon, my friend has offered his place to work on it so I may take that up for the time being seeing as I can't get enough of working on Mila.
    BONUS ROUND
    Just a small bit of rust I've found.. will be cutting this out and welding new metal in soon hopefully. I also know this hole will be much much larger once I actually take a wire wheel to it..
    Nasty glob of silicon that the PO decided was the best way to reattatch the rear bumper + apron after he broke the car side mounting point.. terrific.
    Kind of a glory shot but not really... more like a wounded patient more than anything.
    Anyway, until next time! :D
    • mila325
      • Sep 2015
      • 82
      Oh, also. We sold the 323i that my girlfriend had for a nice chunk of profit, so that's going to help keep the progression going. We're a little sad as it was an extremely nice, clean and stock example but we will move on. Just happy that the car went to someone who will preserve the cars history and not ruin it.
      • mila325
        • Sep 2015
        • 82
        Decided to dismantle my Recaro seats. Here's a link to the thread if anyone is interested, didn't think that it would suit here. I'll be continuing on with this for sure, and can't wait to do some upholstery work.
        • c0rbin9
          • Dec 2015
          • 609
          Reminds me of my car, being a somewhat abused example, complete with random holes drilled, hidden rust, improperly installed parts.
          Also reminds me of my car in that it looks pretty nice from the outside. Those type of cars are dangerous - because you'll be all frustrated that so many things need to be fixed and think about just selling it, but then you'll see it sitting pretty in your driveway on those BBS wheels and keep dumping money into it.
          1991 318is Brillantrot daily driver (slow restoration)
          • mila325
            • Sep 2015
            • 82
            Haha, I can't say you're wrong on that at all. It's defiantly been abused, but when I get my shed in about a months time I'm going to completely strip her down and rebuild.. probably going to take a very long time :D I love this car too much, and since I crashed my first one I want to do her right.
