My project 84 318i
This topic is closed.
  • Jean
    • 18228
    #361
    Yep, it appears to make a difference, oil light was on for a split second on start-up this morning after the car sat overnight where in the past it would be on for about 5+ seconds in the early mornings with generic oil filter.
    New oem subframe & trailing arm bushings will get installed in the next week or so, I gotta pick up a set of front/rear pads and maybe do it at once in time for this car's last autocross. Hehe.
    • el bob
      • Feb 2006
      • 348
      #362
      Hey Jean, do you have any video of your car at the autocross?
      • Jean
        • 18228
        #363
        I don't sorry. There is going to be an "enduro" (saturday practice runs, sunday one run on the same course as saturday) event next month, and I might have a clip then...
        • scabzzzz
          Estado de mierda de encargo
          • 6871
          #364
          Car looks great Jean. Dont change a thang.
          • Jean
            • 18228
            #365
            Thanks man!
            Last bit of suspension that was overdue for an overhaul....
            Had a shop press new wheel bearings into my spare trailing arms from the 325i and got new oem subframe and trailing arm bushings since it's a dd.
            $28 something from autohaus az.
            Bushings and e-brake shoes I bought a year ago from bmaparts and just now got around to installing
            Had a shop press the new bushings in, $60 a side including hot tanking the arms.
            old vs. new
            Gotta love stupid e-brake shoes.....
            New subframe bushings pressed in and subframe ready for assembly
            view from the bottom
            You do not have to remove these bolts, they can stay in place when you install the subframe with trailing arms
            subframe with trailing arms/diff ready to go
            don't forget the upper washers
            Installed
            Found out that my rear driveshaft u-joint is bad... doh! flex disc is still good though...
            new bushings
            All said and done took about 5-6 hours from start to finish, with pressing new bushings into the empty trailing arms and subframe, changing e-brake shoes, and transferring the rear axles and brake hardware from the old trailing arms to new.
            Feels "fluid" on the road now, where before you would feel that the rear end would kind of "crash" over the un-even road surface or pot-holes, now it doesn't do that anymore.
            So, well worth it in my book.
            • Pinepig
              • Sep 2007
              • 1811
              #366
              Do you know how I know you are gay, you stop and take pictures when you should be wrenching.
              Looks like you slipped a few extra pics in when I went to drop a deuce.
              • Jean
                • 18228
                #367
                Lol! btw enduro isn't until the 18th and 19th, you should go!
                • Pinepig
                  • Sep 2007
                  • 1811
                  #368
                  Maybe I will, I'll have to set the boost back down to 15psi.
                  • Jean
                    • 18228
                    #369
                    Finally my car has heat, for the record e30 325i heater core valve works just fine in place of 318i valve. I installed new hoses, hard and soft and o-rings. Now I don't have to freeze my balls off in winter....
                    My new odometer gears from spain arrived, $23 shipped.
                    Car is happy about the outcome lol
                    E34 leather e-brake and e30m3 boot.
                    Almost a perfect match
                    Things left to fix / do
                    1 - replace driveshaft (rear u-joint is bad)
                    2 - replace lock cylinders to match the master key and align the door
                    3 - replace the crappy m10.
                    4 - finish a/c work
                    5 - replace headliner?
                    • E30_Pare
                      • 7801
                      #370
                      I like your interior. Cloth is more comfortable IMO, but my cloth seats started to tear up so know I have leather :zzz:. Anyways nice ride!
                      DREWLIENTE
                      1$ PShops PM me
                      • e30edward
                        • 777
                        #371
                        love those seats man!
                        where did u order those gears from?
                        that's cheaper then odometergears.com
                        • Nicademus
                          • 2912
                          #372
                          and where did you get the ebrake boot.
                          Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
                          ~ John Adams ~
                          • Jean
                            • 18228
                            #373
                            The gears are on ebay, search for e28/e30 odometer gears. I'll look up and post the sellers ebay name if you don't find it. The e-brake boot is a stock e30m3 boot, it comes with the metal ring so it mounts correctly to the e-brake console w/o having to do any modifications or anything.
                            • Jean
                              • 18228
                              #374
                              Here is the seller I got the gears from, highly recommended - http://motors.shop.ebay.com/merchant/sportevolution
                              • hugh jass
                                • 2220
                                #375
                                where is the shop at where you did the work? is that pinepig's haus?
                                ______________________
                                ex-Chief Operating Officer
                                Blunt Tech Industries
                                West Coast and Pacific Rim
