My 89 daily - yep, another m30b35 car
  • Jean
    • 18228
    Picked this POS a few weeks ago, took a train out to SJ and got it sight unseen. Let's just say it looked better in photos on CL ad than in person.
    Talking about "Filthy" interior, and headliner, a,b,c pillars and rear parcel shelf looked like crap with aftermarket microsuede job. Just little things here and there missing or broken.... the only good thing was how well it drives, no shakes ...solid handling ...basically PO took care of suspension aspect and clutch and ignored the rest lol.
    I knew I wasn't getting a perfect car, but if it was solid otherwise I was wiling to put some time and money to save her.
    Had REALLY crappy interior, worn out seats, torn rear seats, broken passenger seat, bad door panels.
    Broken bumper side bracket.
    Not working driver side door latch and lock mechanism
    Broken driver side passenger window (I found metal sliders for the glass was detached from the glass, and laying on the bottom of the door)
    Filthy consoles, and switches as if someone lived in the car and spilled a can of soda or something.
    Not working cluster, non of the gauges would work other than temp gauge and sometimes tach and speedo...
    So far I've done the following-
    - replaced broken dash speaker covers
    - replaced shitty door panels for late model panels
    - replaced worn/ripped rear seat
    - replaced front broken seats for a set of good working/soft heated seats
    - replaced a/b/c pillars for a match tan late model set
    - replaced rear speaker parcel shelf
    - replaced driver side door lock/latch
    - replaced driver side door stop
    - replaced all 4 door seals
    - replaced glove box and trip for matching black with wood trim to match the door panels
    - replaced broken bumper side mounts
    - replaced cracked sun visors for late model versions
    - replaced torn e-brake boot for a good one
    - ordered new shifter boot to replace the worn out one in the car
    - Got trunk carpet (for some reason half of it was missing) installed
    - replaced broken rear seatbelt latch
    Used a whole box of baby wipes to just clean the filthy interior.
    Temporary installed my momo hub/wheel from my e30 until I find a good steering wheel and hub for this car.
    Temporary using a late mode gen2/3 535i cluster while working on the gen1 cluster repair (got all the gauges working except for fuel gauge)
    Still to do
    - install new glovebox
    - swap driver side wood trim
    - fix the HVAC controls
    - fix the steering wheel situation
    - fix clutch pedal/master situation
    - need a good passenger side mirror housing.
    - need to replace passenger side high beam headlight
    - replace windshield wipers
    Car rides really solid it's on new (last year with receipts) Koni yellow single adjustables and H&R sport springs
    Suspension was done, it's got the adjustable mooshead? front control arm bushing/bearings.
    It's on 17" style 32s with square 245 tire setup.
    Came with a set of 750 calipers in the trunk.
    Not sure if I'll keep her or sell her, depends on what I end doing with the 635csi, but for now she is my DD :)
  • kronus
    • Apr 2008
    • 13032
    I have a whole parts e34 if you need stuff
    cars beep boop
    • Jean
      • 18228
      Kronus - pm sent :)
      • Jean
        • 18228
        Installed a later version glovebox with wood trim to match the rest of the interior and really like how it turned out.
        Replaced driver side rear window, the metal tabs on the glass were on the bottom of the door (wtf)... that was fun.
        Replaced front bumper side mounts/brackets, bumper no longer hangs on each corner.
        Replaced driver side door lock mechanism, no idea how the PO managed to brake it inside the door...sigh.
        Got a set of late model e34 side mirrors and found out the pig tail/connectors are different FML
        To do next :
        - clutch master cylinder
        - rear headrests
        • flyboyx
          • 8371
          at least the seats look good? paint doesn't look bad either.
          Gigitty Gigitty!!!!
          • Jean
            • 18228
            She is a 20 footer ! The strong point of this car is dialed in suspension , but the engien feels tired.
            Started having driveline vibrations, goes away when in neutral or when not under load. Ordered guibo and CSB...will get to it when my back feels better and doctor says its ok.
            • Jean
              • 18228
              New guibo done, CSB looked fine so I left it alone.
              Replaced old exhaust hangers.
              Listened to someone who said these cars sound great w/o muffer, cut the muffler out and couldn't stand how loud it was. Doh!
              Fixed the gen1 cluster, all gauges work and mileage is accurate.
              If anyone needs e34 cluster help let me know, I know know these inside out and can test them on the bench.
              • kronus
                • Apr 2008
                • 13032
                I've got a b&b catback for this specific car sitting around btw
                cars beep boop
                • Jean
                  • 18228
                  You should see / hear what my exhaust sounds like after a local muffler shop did their thing . Louder than my e30!
                  • kronus
                    • Apr 2008
                    • 13032
                    Your e30 isn’t that loud! I was actually pretty surprised.
                    cars beep boop
                    • Jean
                      • 18228
                      Yeah I am happy with how it sounds, only loud when you really step on it otherwise it’s quiet enough ��
                      E34 on the other hand is louder ! And it has stock silencers , maybe they are dead and shitty cat previous owner installed is bad as well as she wouldn’t pass smog last year when I wanted to sell her.
