Don't use ego correction while tuning ve map. It will make it almost impossible to fine tune values. Alao disable AE also. Use only very slow thorttle movements when tuning VE to make sure that the required AE doesn't cause lean spikes. Only when you have whole VE table tuned, turn on the EA and adjust that so that the engine doesn't stumble when thorttle is pressed more quicly. When that is done, you can enable ego correction. But when VE table is correctly tuned, there is not much need for that.
EDIT that AFR dip is just your AE settings. The TPS dot threshold is too high. But as I said. Don't worry about those yet. Tune the VE table so that AFR is good with stable TPS and then start tuning the AE. I would also suggest changing the lowest RPM row to about 5-600 RPM. To tune that, put the car on first gear. Start driving and keep the RPM and below idle level using brake and using throttle you can reach all the map cells there. Autotune is your friend here. This works for higher RPM also.
