Hello, in this thread I will be documenting the progress of restoring my 318is.
I am a Mechanical Engineer that live and work in Dubai, UAE, and I drive a Toyota GT86.
In my home country, Lebanon, I wanted to have a car that have similar driving characteristics, and a project car I can work on and bring back to stock condition during my vacation days (around one month each year).
So I began searching online for one, and it seems in Lebanon nobody knows what a real 318is is. All kinds of 318i were claiming to be one, some with 4 doors, some with automatics, some with the wrong engine, ect... until I managed to get in contact with someone who sent me the car registration form showing the chassis number which I verified online, it was:
Looking at the photos of the car, it was looking a beater neglected car:
Since I was living abroad, I sent my father with a mechanic to inspect the car.
It had no maintenance history, and the odometer has stopped working at 160,000 km.
The seats were leather sports seats from an E36.
So I got the car for 3400$, and took it to a body shop to do some repairs on the damaged front fenders:
On to the maintenance issues, addressing the known problem areas:
1- Changed the chain tensioner with the upgraded one:
2- Replaced the fuel pump as it suddenly stopped working one day while driving.
3- Replaced the water pump.
4- The car was reaching normal operating temperature (at the half way mark) after 30 min of driving, so I knew the thermostat was broken, and it was:
I replaced it with a new one that opens at 88 deg. C.
The radiator with flushed with chemical couple of times, and new organic coolant was added instead of tap water:
1st flush result:
5- Changed the spark plugs, fuel filter, air filter and radiator hoses.
6- When changing the transmission oil, this was the quantity found inside:
Now it is properly filled with 1.2 liters of 75W-90 GL4 gear oil.
7- I changed the engine oil to a synthetic 0W-40 grade oil.
9- Around 50% of the fuses in the box were above the required rating, so I replaced all of them.
The previous owner was so cheap, he used metal wire to fix a melted fuse:
9- Replaced the airbag steering wheel with an M-Tech 1, got the missing kick panel underneath it, and replaced the plastic shift knob with an original leather one:
11- The car was idling roughly, so I cleaned the Idle Control Valve.
Problem remains, further inspection for vacuum leaks will be required.
12- When you press the gas pedal all the way down, the car was not revving properly and felt choked.
I added fuel cleaner to the tank, but it showed no improvement.
I decided to inspect the injectors and clean them if necessary, and I found the 4 injectors like this:
I installed new o-rings and cleaned the injectors in a special shop.
The problem was not completely solved, will still have to check for vacuum leaks.
13- looking at the radiator, there was no temp. gauge switch: the installed radiator is not the proper one to use in conjunction with an AC.
Also notice how the fan shroud is not covering the fan completely.
I will have to replace both of them later on.
14- Rear shock mounts were completely damaged, replaced the with E46 ones with reinforcement plates.
15- The shift linkage is so loose you can move the arm carrier with your hand.
I am planning to replace the bushings in the future and install a shorter Z3 shifter.
No idea how that green foam piece got in there.
16- When I lifted the car, I noticed the tag on the differential (photo below) is showing 3.45 instead of 4.10
So sometime during the life of the car, the diff. was changed to one with significantly longer gear ratios.
I will look for a 4.10 diff and replace it when I find one.
17- The tachometer and fuel econ. gauge were not working.
I replaced the SI battery but no success...
18- Data for the journey ahead:
Thanks for reading.
1st flush result:
Thanks for reading.
