Will 87 325is window motors work in an 88 325is
  • Traviair
    • Mar 2018
    • 7
    I have an 88 325is e30 and I'm going to buy an 87 325is that has a built motor. The windows in my 88 don't work and was wondering if just swapping the motors over from the 87 would be possible.
  • KIRIEIW
    • Dec 2012
    • 3385
    Go on http://www.realoem.com/ and type in the fields for both 1987 and 1988 model years/ look if the part numbers are the same. Off the top of my head they changed the regulators sometime between the two years but uncertain if the motors are the same.
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
    • kyleconstantine
      • Apr 2014
      • 1380
      They changed motors 9/87 so if its built after that its the same as 88....the older style works if you drill one hole in the door but the older style tends to sieze up so i would recomend finding a later one.
