weld it.. and it wont rust
Project Facelift
self etching primer is not a sealer, only aids in paint sticking to bare metal. the topcoat is the sealer or an epoxy primer/ sealer is needed. self etch the bare metal and when painted with the topcoat it will be sealed. also fiberglass not sealed over with paint will only trap and hold moisture between it and the other surface, as it is porous. good luck and keep us posted. im sure it will look great when finished.
We'll be doing a light coat of self etching primer on the bare metal front valence, then the standard primer, then paint.self etching primer is not a sealer, only aids in paint sticking to bare metal. the topcoat is the sealer or an epoxy primer/ sealer is needed. self etch the bare metal and when painted with the topcoat it will be sealed. also fiberglass not sealed over with paint will only trap and hold moisture between it and the other surface, as it is porous. good luck and keep us posted. im sure it will look great when finished.
Don't worry Kevin, huge progress is coming this weekend!Last edited by Jand3rson; 09-29-2006, 10:02 PM.Comment
That is why I said primer is not what keeps metal from rusting. Paint is. This is why prep is so important. If you don't remove all possible contaminants from the surface that is being sprayed, rust WILL form, regardless of what you spray on it.Originally posted by Ritalin KidRegular automotive primer is not a sealer and is water soluable. It will soak up moisture and eventually cause rust bubbles.
Not true. My father and I put in around 100 SS pop rivets on a bunch of trim on our river sled (boat) a few years back with only a hand riveter. You just have to have a good quality rivet gun that can handle the extra strain of SS rivets.
Finally, someone who speaks the truth.Originally posted by mentaleeillself etching primer is not a sealer, only aids in paint sticking to bare metal. the topcoat is the sealer or an epoxy primer/ sealer is needed. self etch the bare metal and when painted with the topcoat it will be sealed. also fiberglass not sealed over with paint will only trap and hold moisture between it and the other surface, as it is porous.Comment
Probably more or less the same thing.
Mike, just to let you know, Andy and I ended up going with the method that you used, rather than Jordan's. But instead of just cutting the skin of the bumper (at least, that's what it looks like you did), we went ahead and cut through the entire bumper, taking it all off in one solid piece.Last edited by Jand3rson; 09-30-2006, 10:54 PM.Comment
dude i cant wait to see the finished front bumper. lookin good, more pics man more pics.Comment
Oh, so you cut through the black plastic behind the skin? That is not what I did but still works the same. Why did you change to my meathod? Just wondering? How did it turn out? Pics damn it:pProbably more or less the same thing.
Mike, just to let you know, Andy and I ended up going with the method that you used, rather than Jordan's. But instead of just cutting the skin of the bumper (at least, that's what it looks like you did), we went ahead and cut through the entire bumper, taking it all off in one solid piece.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
Trust me guys, there are shitloads of pics, I'll have them uploaded in a few hours, when I get home. I'm still over here at Andrew's house, but the chopping and bonding of the rear bumper and trim is DONE. The pieces are back together, bonded hard as a rock with fiberglass. We're going to let the fiberglass harden overnight, and then in a day or two, bondo the seams and get everything ready for paint.
Mike, we decided to go with your method after reading through Jordan's and kind of realizing that his method was WAY more mork than is actually needed. What he did worked great and came out looking really good, but it's more than you need to do. And with the way you/we did it, you retain the OEM end of the bumper, which I would rather have. I know you guys are chomping at the bit as much as I am, I'll have lots of pics for you very soon. :up:Comment
That is how I felt with mine. Let me know if you have any questions with it. How are you reconnecting the two halfs? Oviously don't use bondo;) Maybe fiberglass?Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
