New to BMW
  • McGD4
    • Feb 2019
    • 3
    New to BMW
    Hi,
    I am very new to bmw and mechanics. I just bought a 1988 BMW e30 325i that has a m20b27 engine.
    I was not expecting spark at all when I went to do spark test last night, because owner that sold it to me said it doesn’t run.
    When I did the spark test the car did start up.
    Spark plugs were full of oil, lower oil pan leaks, lots of oil when degreasing engine bay, interior has cables not plugged under steering wheel, driver side rear axel is off, exhaust is off and has no muffler, transmission seems to work well.
    Does not let me post the phots/videos
    Where would I go from here?
  • Supadave
    • 1006
    Write it all down and start where your budget allows.
    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
    • tomstin
      • Mar 2015
      • 571
      I would clean the engine to eventually see where it leaks. Then a compression test, if all the cylinders are reasonable and even, that would be a good start. Timing belt, tensioner and water pump, check all the hoses. Plugs, wires cap and rotor. How does it run? Maybe add a exhaust system while your at it so you don't piss off the neighbors while you work on this beast.
      Once it runs and your comfortable, then that axle needs to be replaced. Then I would move to the brakes. Has to run, then stop. All the rest are extras.
      I'm sure others will add, but my favorite parts places:
      https://www.pelicanparts.com/BMW/index-SC.htm
      https://www.getbmwparts.com/
      2004 525i Manual - 1985 325E Coupe Manual
      • cheffy30
        • Sep 2016
        • 1159
        like i always say...
        change the timing belt.
        post some pics of your girlfriend.
        like others say... buy the bentley manual and read it through
        drive it like you stole it.
        '90 325i sedan daily driven
        '85 325e coupe also a daily
