Replaced the starter.....turns out the new one is non functioning as well. Hate wasting my time.
What did you do to your E30 today?
This is a sticky topic.
Originally posted by M-technik-3 View PostReplaced the starter.....turns out the new one is non functioning as well. Hate wasting my time.
So I was doing my thing and some how did this:
So I called AKG for warranty, and they were nice enough to give me this:
And I just finished doing this:
I'm a happy camper.
I tore my passenger door apart to see if I could fix my Window regulator. Found out it needs replacing. Also found out my door cards are fucked. Time to switch to different cards. Gonna try to get black door cards with cloth inserts for my 4 door.Float like a cadillac sting like a Bimmer!:)
Started putting my freshly powder coated trim back on. Putting the trim back on rear side windows is a PITA. Got aother tweeter for the driver side. And A/C lines and receiver dryer. Hopefully A/C in a couple of weeks.How to remove, install or convert to pop out windows
I got the windows back in. Soldered in an inline fuse. And started it up for the first time in a long time. Sounds good. Still piecing together my exhaust. Looked for more much needed parts. Got a steering wheel washer.How to remove, install or convert to pop out windows
Driver side weather stripping(around door frame)replaced. Installed new to me Driver side door sill. Installed purge valve.How to remove, install or convert to pop out windows
-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good looking
I installed my skid plate. And then scratched it. I also got to drive it again for the first time in about a month. I love this car. Fan didn't work, I have to replace the fan relay.How to remove, install or convert to pop out windows
Finished my Hella fog light wiring and found a fun place to put the switch that does not require drilling holes into any part of the dash. The cigaret lighter of cores. I dont smoke and I dont need any 12v sores for charging as my head unit has a USB port, so this is perfect for me. With a bit of work with some needle nose pliers and a sharp blade the button Hella supplied with the lights just popped right in!
Worked on installing trim pieces. Dropped a nut down in the a pillar, so I had to take the rear side card out to find it. Worked on my horn. Bought a new muffler.How to remove, install or convert to pop out windows
