Found out it's broken.
What did you do to your E30 today?
This is a sticky topic.
Originally posted by deutschman View PostFinished my Hella fog light wiring and found a fun place to put the switch that does not require drilling holes into any part of the dash. The cigaret lighter of cores. I dont smoke and I dont need any 12v sores for charging as my head unit has a USB port, so this is perfect for me. With a bit of work with some needle nose pliers and a sharp blade the button Hella supplied with the lights just popped right in!
Originally posted by DEV0 E30You'd chugg this butt. I know you would. Ain't gotta' lie to kick it brostantinople.
I got my a/c compressor, compressor bracket, and tensioner pulley. Muffler showed up in the mail today. So did my harness cover.How to remove, install or convert to pop out windows
89 325i 4 door - current project
88 325 V8;D - next project
my 325 build
M20B27i FORSALE maimi fl
I bought a set of pop out windows, can't wait to swap them into my car.How to remove, install or convert to pop out windows
New serpentine belt, and harmonic balancer/crank pulley and finally got a steering wheel washer so I can install my steering wheel.How to remove, install or convert to pop out windows
Built a GoPro camera mount that nolts to my head rest. Square bar aluminum tubing, two U bolts, two square black plastic furniture end caps (bulk hardware section), and some paint. Ill use a GoPro sticky mount, but if you have a different camera you could also buy a super cheap tripod camera base and screw it onto the aluminum bar.
Originally posted by deutschman View PostBuilt a GoPro camera mount that nolts to my head rest. Square bar aluminum tubing, two U bolts, two square black plastic furniture end caps (bulk hardware section), and some paint. Ill use a GoPro sticky mount, but if you have a different camera you could also buy a super cheap tripod camera base and screw it onto the aluminum bar.
my 325 build
Really cheap as well. Most expensive part was the paint lol
If you want to mount a regular camera you can get something like this from Amazon or Walmart or something. Maybe scavenge the top off of a super cheap tripod.
