What did you do to your E30 today?
This is a sticky topic.
  • Powling
    • Jan 2015
    • 1291
    #5701
    Originally posted by Idrisu
    new wheels
    What is it about you and getting my dream wheels?!
    Futura's are top of the list...SSR Mesh's are in the top 5 too.
    Steve • Toronto
    1991 318is • Brillantrot
    Build Thread
    • Glaede
      • Oct 2007
      • 138
      #5702
      Installed an old school Blaupunkt RCM 82 Frankfurt headunit. Not in perfect condition, but works and damn cheap :-)
      • miagi
        • Jun 2018
        • 6
        #5703
        Ser fint ud. Har selv sat en
        BMW REVERSE RDS C52 i min og fået loddet aux stik ind i printet så jeg kan køre trådløs fra min telefon.
        • loloe13
          • Jun 2014
          • 4
          #5704
          good taste!!!
          I got the same set up! also did a wired in Aux line for extra input. Putting in period correct unit looks much better
          • miagi
            • Jun 2018
            • 6
            #5705
            It does indeed look best with a period correct unit ;-)
            • Glaede
              • Oct 2007
              • 138
              #5706
              Ser også godt ud! Cool med aux, det har den her Blaupunkt også bag på [emoji4] Så har bestilt et aux stik så jeg kan lave Bluetooth.
              Sendt fra min CLT-L29 med Tapatalk
              • cheffy30
                • Sep 2016
                • 1159
                #5707
                tranmission mounts
                guibo
                center bearing
                rear axels
                tranny flush and seals
                power sterring flush
                enough for one day.
                sent from hell using Tapatalk
                '90 325i sedan daily driven
                '85 325e coupe also a daily
                • b33mer
                  • Jul 2018
                  • 16
                  #5708
                  I solved many mysteries related to the window motors. After several months all 4 are finally working.
                  1985 318i - M20B25 5-spd swap
                  1986 325e - "302i" 5.0L T5-spd swap
                  • TeXJ
                    • 1914
                    #5709
                    installed my red46 skid. Had to add another piece of metal so that the skid had something to bite into. The core support where the skid should have mounted was all mangled.
                    1990 325is
                    m52b28
                    3.73lsd
                    g260 (1987 325is 5spd tranny)
                    • Von Soman
                      • Dec 2018
                      • 48
                      #5710
                      Delivered a craigslist M20b25 with 88k to a Foreign Auto Tech in Redlands Ca. They are going to do A valve job, new water pump, oil pump, rear main seal, timing belt and a few other things to it. Then Install it on my 1990 325i. Looking forward to getting to drive this car.
                      • 325isman
                        • Dec 2010
                        • 299
                        #5711
                        Tried toget my barn find 86 325es started
                        • efficient
                          • Feb 2012
                          • 3312
                          #5712
                          just seen my car from the 2nd floor of my house and said to myself soon ill take you out for a spin
                          • LowR3V'in
                            • 4209
                            #5713
                            so i had to replace the clutch slave because i'm stupid.
                            Replacement was on the more expensive side.
                            sachs being like $15 bux. mine is matalli @ $35.
                            made out of cheap chinease cast iron.
                            But the one i took out was a niiiiice, and aluminum, that's $123.
                            dammit. oh well...
                            $125 by jet jones, on Flickr
                            Nice by jet jones, on Flickr
                            • LowR3V'in
                              • 4209
                              #5714
                              i did this acouple days ago.
                              check out the balancing holes.
                              never had one balanced looks like they are not very balanced at least 30 years later.
                              Balance puck by jet jones, on Flickr
                              • Singulaarity
                                • Sep 2018
                                • 37
                                #5715
                                This past weekend... Painted engine bay, front subframe in, rebuilt z3 rack, put on front suspension and got the entire chassis back rolling.
