This is going to make my S52 swap feel underpowered and weak. Very nice work and writeups. I look forward to seeing it in person someday.
E30-ls1
You failed to show the strength of the Factory rubber motor mount loaded off center being pulled straight up. The original design is centered and pulled at almost a 90 degree angel. The weak point is the stock rubber mount not the metal one you built.I have been busy running down the last (almost) parts we need; PS hoses and fittings (hydraulic supply shop has JIC 3/8 (like AN6) fittings for the PS hoses for about $3.00 ea)
Had to drop the radiator off to have the RH end cap swapped since the outlet was right in front of the A/C pulley; new cap for about $75.00
To those who thought that our engine mounts looked weak:
Here is the FEA loaded with 3G's vertically and horizontally and it only used 1/3 the ultimate strength (i.e. it could handle up to a 9G bump)
-GarretComment
FEA Pic
Keep in mind that the rubber mount "does not know" how the load gets to it. The cranked arm of the mount sees bending and torsion stress, but the rubber mount itself sees nothing but vertial loads, and some braking loads.
If the mount weldment was very "springy", then the rubber mount might see some torque on it around the Z-Axis (cross-car). As it is, the mount weldment deflects very little (<.005"). See our pics of the loads on the mounts: 260lbs on each engine mount, 83lbs on the tranny mount. What you see in the FEA is 3x the static loads: 750lbs vertical combined with 250lbs fwd-aft. The rubber mounts we used are BMW E34 / M60; the M60 engine package is heavier than the LS1.
(Steve, PE, C.Eng)
Garret & Steve almost done with E30-LS1; just got to run down brake & PS fittings, etc.Last edited by garretvs; 10-03-2007, 05:52 PM.E30-LS1 aka. 357is
email us to pick up our LS1 swap guide
E30-LS1 KITS now available!!
E30LS1@gmail.com
e30ls1.com
E30-1UZ; just got to run down brake & PS fittings, etc.
Same as me to! oh and the link computer tunesigpic340hp V8 e30 FINISHED!!!!!
Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
NEW One on the track :)
http://www.youtube.com/watch?v=K-AX5SzSLnk
Cleaning up some 911s and Jap turbos
http://www.youtube.com/watch?v=Ad79wsLdle4Comment
Awesome work! I'm trying to finish my fourth year of a Mech Eng degree down here in Pasadena this June. I chose the turbo route for my car.
That brake booster is sick! I would love to see the drawings if you don't mind. What program did you use for the stress/load analysis on the engine mount? Is it part of a CAD program's toolbox? I'm mainly a SolidWorks guy but should probably get around to learning some of the more industry standard pieces.Comment
We used Catia V5 for the CAD work (we use it on our 787 work) and Algor for FEA.
Garret & SteveE30-LS1 aka. 357is
E30LS1@gmail.com
e30ls1.com
Catia FTW, that's what we use at OSU for all of our SAE Formula and Baja stuff. You work at Boeing? I have a few friends that just finished up internships there working on 787 stuff.Comment
Our company (I work there & Garret has done summer interns there (he designed some equipment for the 787 program)) supplies assembly equipment for the aerospace industry. We have worked on AirBus, Boeing, Lockheed etc programs. Our 787 work included all of the equipment necessary to assemble all of the major sections of the airplane: 6 fuselage sections, join wing to body, install empennage.E30-LS1 aka. 357is
E30LS1@gmail.com
e30ls1.com
