★★★★George Graves★★★★ Project Blog for e30 Gizmos and Gadgets - 2025 UPDATE
  • AndrewBird
    The Mad Scientist
    • 11898
    #391
    I made this for my (ex)girlfriend for this past valentines day:
    All soldered by hand with an iron. The switch and battery are on the back.
    Stuff is looking great. My question is, what are you using to take the pictures? Those are some amazingly detailed shots.
    • einstein57
      • Jun 2007
      • 10780
      #392
      Macro Lens FTW. You can pretty much touch the lens and still be in focus.
      www.gecoils.com
      • MonkeyMadness
        • 3251
        #393
        OMG! subcribed...
        I want the boost gauge in red..!
        • trackjunkie21
          • Jan 2010
          • 3962
          #394
          That is so awesome, you have probably been asked this a million times but, What did you major in? Electric engineering?
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • george graves
            • 19992
            #395
            ^That's cool NitroRustlerDriver. And yes, you can even solder them by hand in a pinch! A quality iron will help with that. But it's tedious, and leads to problems. You actually have more of a chance of overheating parts by hand soldering them where the temperature can't be controlled as carefully as an oven can be. When soldering by hand your iron needs to be much hotter than the melting point of the solder, and how hot the part gets is determined by how long you touch the iron to the part. (there will even be a spec in the data sheet telling you how much heat it can withstand for how long) If you have to work the part for too long (human error) - it will lead to over-heated parts(it turns out that even large parts are so small that they basically get just about as hots as the iron does) - ...Anyways, I'm rambling...I'm really tired...
            Speaking of rambling......People keep asking me about making an Alpina style vent gauge - and here is the reason why I'm not a fan of them - I ran into this today - this is a vent gauge set up from a e9x 335i that someone created using generic gauges. You'll see all the problems with them, mainly the reflections. That and the LEDs that look *really*peaty in pictures, but are washed away during the day. You'll see that even though the sun in coming in from the front of the car, the gauge is hard to read. In direct sunlight it would be even worse. (Some of the glare is because of the sun light hitting the camera - but it's clear when the camera moves around that there are issues with such a set up.) Even if the glare wasn't an issue, you'll see that the generic gauges LED's are no match for daylight brightness.. I'll let the video (not mine) speak for itself.
            This is an example of what you don't want me to build.
            I just think there is a better way to do it.
            New city. New start.
            So most of you know what a ruff go I've had while back. Things are finally back on track and....I'm moving!
            I'm moving to Seattle (to an undisclosed location ;) ) Yep - I've joined the PNW conspiracy - so I'll be seeing many of you at the e30 picnic! Woot! I should have some surprises by then. Off to finish packing....grrrr. I need more boxes....
            Originally posted by Matt-B
            • pegase747
              • Jul 2006
              • 279
              #396
              Hi Georges,
              good luck on your move !
              Regarding the Alpina Gauges, did you see some in real life ? I have them in my B3 and I can tell you that even in bright sunlight they are visible.
              They are bright, recessed a little and I can not fault them. Also they can be angled up and down.
              Now on the one you show here, it looks like the LEDs are behind some kind of flat clear plastic, which give a lot of glare. As well it is angled up which will add some more sunlight to it. definitely can not compare with the Alpina vent.
              Now if you come up with some nice gauge design, I will be very interested to see what you come with.
              Keep up the good work !
              Cheers Pierre
              1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
              see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460
              • samiam3356
                • Jul 2009
                • 1901
                #397
                sub'd for future projects
                Originally posted by Roysneon
                $5 shipped?
                Originally posted by MarkD
                You are a strange dude, I'n not answering any more posts from you.
                • europeanplates
                  • Jun 2005
                  • 1607
                  #398
                  Welcome to Seattle.
                  Tyler
                  http://www.europeanplates.com Build and Preview plates
                  R3V Discount Code = R3V2012
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    #399
                    wooow...I hope its not to late to subscribe
                    m20 is plenty. im simply a drifter.
                    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                    • IronmanE30
                      • Sep 2009
                      • 2121
                      #400
                      Looking good George!
                      Cheers,
                      Jim
                      • ZM Blue Devil
                        • Dec 2006
                        • 13836
                        #401
                        those are beautiful George.
                        Levent
                        %20levent@gutenparts.com
                        Ladies:
                        • ScHpAnKy
                          • 1573
                          #402
                          Even though any price drop compared to the stupid-inflated alpina is appreciated, I still hope it's not super over-priced ($200+)
                          also, this:
                          91 318i | 87 535iS
                          • Schnitzer318is
                            • Jan 2008
                            • 2057
                            #403
                            ^Depending what it displays I'd pay good money for that. $300ish... maybe a tad more.
                            "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                            91 318is Turbo Sold
                            87 325 Daily driver Sold
                            06 4.8is X5
                            06 Mtec X3
                            05 4.4i X5 Sold
                            92 325ic Sold & Re-purchased
                            90 325i Sold
                            97 328is Sold
                            01 323ci Sold
                            92 325i Sold
                            83 528e Totaled
                            98 328i Sold
                            93 325i Sold
                            • ScHpAnKy
                              • 1573
                              #404
                              If it did oil pressure, A/F and a few other things I'd splurge to maybeee ~240
                              But with much regret
                              91 318i | 87 535iS
                              • e30m3s54turbo
                                • Jun 2010
                                • 3218
                                #405
                                Very nice!
