★★★★George Graves★★★★ Project Blog for e30 Gizmos and Gadgets - 2025 UPDATE
  • george graves
    • 19997
    So, many of you have seen my interior light delay with auto dimming that I make
    Hopefully this will spark some creativity from you all to go and explore on your own.
    So - ENOUGH of that BS, just what the hell is this? Well, my car is not turbo'ed. No Mega-squirt. I have no real need for super huge gauges all over my dash. I like the stock *look*. But I wanted to add an extra gauge here or there, and yet have the interior look totally stock. So – I'll be needing to "sneak" these in the dash some where. Where is the question. I don't want "pods" of things looking like rice cakes poking out of the a-pillers.
    I thought about sneaking it into the instrument cluster - but that requires a ton of work.
    How about INSIDE a hollowed out hazard or defrost switch? That would look pretty stock? Not to mention no cutting or drilling - just pop out one of the "blanks" and slide that puppy in. Yea that will do - can it fit? I bet it can.
    I happened to have a few extra switches lying around. Time to crack one open.
    They take some persuading to get them open. Two small screwdrivers does the trick.
    The 20 year old innards spill right out. All I care about is the front of the "bezel/case" and the front "button" - The button is a bit thick and dark, but I have a plan for that.
    So - about the only "display" you can squeeze into a hazard switch is a LED bar graph. Perfect for a simple gauge - I don't need a numeric display - just something much smarter than a dummy light - and something less than a laptop riding co-polit.
    A quick look at my boxes and boxes of parts lead me to the venerable LM3914. It's a linear LED driver. Basically you tell it the limits of the signal it will receive, and then you feed it a signal, and it can drive 10 leds to make a guage.
    It's made by National Semiconductor - and it's pretty fool proof. In testing it - I threw 20 volts on it's input pin, and everything else to see if I could fry it - no go - it's a trooper.
    Next step - pull out the parts - I have dozens of boxes like this.
    Fast forward to some internet searches on the LM3914 and I'm 90% there - throw in a diode to protect the circuit, and some capacitors to filter the nasty input voltage of a car, and a few more for good measure (too complicated to explain)
    After a few hours, I have a good hand drawn diagram - time to fire up the rig...And I have it in the computer - this will help me in the VERY complex part of the project - making the circuit board.
    Now if this was 1992, I'd have to face one of these bad boys...
    I know the parts I need are in there somewhere!!!!
    Oh god - this could take for ever...Luckly - it's all on line...
    After some more research - I know EXACTLY what I want. I'll mock up the circuit - and cross my fingers...
    And it works!!! Ok - I made it look easy, it's not - it's a lot of work.
    Next up - is taking it from prototype to the real world.
    Originally posted by Matt-B
  • StereoInstaller1
    GAS
    • 22679
    George, you have my attention.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • redbull 325is
      • 7471
      Cool location idea..
      My idea (or was it someone elses?) was to replace the checkpannel with an led/lcd pannel.. It would have 6 different read outs on it and would blink in case anything was out of paremeter (rear brake lights, or oil pressure to low, etc)
      Julien
      Build Threads:
      • rs4pro3
        • 5808
        making a DIY air fuel ratio guage? a lot of people use the LM3914 chip for doing that.
        85 325e 2.7 ITB'd stroker
        • T3rd Ferguson
          • Aug 2005
          • 3076
          or is this for lateral g's?
          1989 Bronzit 325ia- Sold
          1988 Delphin 327i- Sold
          1995 Cosmos M3- Current
          • BeirBrennerE30
            • 2740
            whats it measure?
            e30sport.net
            '06 M3 Competition - 6-speed
            '97 Range Rover Vitesse
            • Ral
              • 1486
              I admire your ambition, but how is a couple of LEDs going to be useful? At least do a digital readout so you can have some degree of accuracy.
              I think it's a great idea- you're not really concerned with the numbers usually as a driver for most engine parameters. (He's not using it as a tach.) You're really more concerned with whether something's inside parameters, getting close to being outside parameters, or outside of them.
              OP- props to you man. I took a semester of Electrical Engineering, and was lost the entire semester.
              sigpic89 M3
              • Mtriple
                • 3139
                +1 on the great idea! The VW crowd has something similar and they look great!
                Originally posted by Simon S
                • StereoInstaller1
                  GAS
                  • 22679
                  ^typical...$600 in gauges, 20 year old Blowchunks pullout deck
                  Closing SOON!
                  • Mtriple
                    • 3139
                    Yes, but its "period correct"...
                    • StereoInstaller1
                      GAS
                      • 22679
                      oh yeah, like whitefaced gauges are "PC"....no wai, mang!
                      Closing SOON!
                      • M42Technik
                        • 9781
                        That is really fuckin' cool.
                        Reminiscing...
                          • 34839
                          looks interesting - narrowband, wideband, adjustable? I actually have all this stuff lying around somewhere though if I wanted to make one - but I think I'd rather turn my econometer into an A/F or boost gauge.
                          some of us don't really care about the stereo - my music comes from a 7000rpm inline 6. ;)
                          • StereoInstaller1
                            GAS
                            • 22679
                            I want mine to be oil pressure. Or voltage, oil temperature or damn near anything that is actually useful!
                            BLASPHEMY!
                            Luke
                            Closing SOON!
                            • Simon S
                              • Oct 2004
                              • 3758
                              i hear ya there
                              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
