tryin to make arrangements to get you that front bumper tuesday byreen....i gunna ask greg if he can grab it...ill spot you the money for the time being....PS ...i still got your IX washer bottle
Empty pockets and lazy
Originally posted by E30SPDFRK View PostI primered the fender lips and valence, the rest is still all moldy :)
It will most likely be there, I don't know if it will be running right though.
And the other wheels aren't on yet as I would like to try to save the tires
Well, you cant say I didn't try.
Thursday night after work I went to a junk yard to pull some injectors because I got tired of waiting for the ones from ebay.
Yesterday after work I installed them, but then it wouldn't run at all. Diagnosed it to a fuel pump.
Today, I got up at 8 and went to all the junkyards around. No one close had a fuel pump; the closest place that did was in mass about an hour away. I got there 15 minutes before they closed and had to pull 6 to find a good one. Went home and put it in. Engine started but ran like shit still. Went for a drive anyways and found a crack in the end tank of my radiator. Made it home and epoxied it up. While it was setting, my new injectors arrived, so I went to work on putting them in. Runs like a champ now, but the radiator still leaks a little. Went for a test through the campus and got pulled over for no hood and the steam coming out of the little pin hole leak. Headed home to fix the leak again, came around the last corner and pop! smoke pours up from the engine bay. Pull over to see whats up and there is a steady stream of coolant pissing out of the center of the radiator. Pushed it home, kicked some stuff, and came here to vent.
Looks like the car will not be making an appearance, yet again :-(.
But holy crap, it lights up the tires like nothingByron
Leichtbau
