ultimate dream
  • payney8
    • Jun 2007
    • 899
    ultimate dream
    hey guys,
    Recently was looking through the net looking at kit cars and the like and then i whent screw it. I did engineering at school for 5 years. I'm currently a associate diesel engineer. I'm pretty handy on cad and with my hands. I'll stop modifiying my e30 and take another look at the idea. We modify it to be individual and how much more individual can you get then completly designed and built by me and a few mates. Currently designing chassis structure, already have shell's general shape designed. Once i shade it etc etc. I'll post it up on here for your discussion all comments are welcome good and bad.
    Current engine idea is a horizontally opposed 6 from a porsche boxster with a bit of work. Cams, porting etc etc not really looking to go turbo maybe supercharged. The plan is for it to be a purely track car with street ability. I.e. You can drive it to the track. Any helpful ideas on the engine/transmission will be welcomed. Its going to be mid engine whichever engine i end up using.
    Planned total weight is 600kg. Large amounts of carbonfibre and carbonalloy plus your standard fibreglass will be used for the outer shell. Inner shell undecided what steel will be used any opinions will be welcomed as before. Will be updating continously
  • Burnall4
    • 145
    honestly i would ditch the porsche flat six and go with a Subaru STi motor, i know its probably a suggestion that will find much criticism on a German Car forum. However I have been a subaru fan for a while and have owned 3 Sti's and these motors are unbelievable. Plus you can find them for next to nothing, where you are located bec Japan is so close! Its already turbo charged and with some modifications it can easily hold 500 whp so you can drive it to and from the track! and it is easily converted into RWD, you could even do an LS2 out of a Vauxhaul (the four door version of the GTO that is for sale in Australia)
    just my .02
    Burn
    keep us updated!
    • So Live
      • 2512
      STi's really arent that cool. Your better off with a bimmer motor. For my untuned 7psi car to keep up with a decently modded STi, i am really really unimpressed with their performance. The STi deal is a whole lot of hype.
      Sounds like a really cool project dude. Keep us posted and best of luck.
      The boxer sounds cool, im not very familiar with the performance of these motors but if you like em, go for it and make it work.
      -Chris
      • payney8
        • Jun 2007
        • 899
        thanks for the help the problem with the sti motor is i will need to run intercoolers which means more ducting. or i could run water cooled which means more weight. i am already running twin radiators at the front for a better weight distrubution. The idea of the porsche is that the gearbox is already designed for a mid-engine frame were as the sti motor is designed as an awd. Therfore to go rwd i need to purchase a new g/box and i believe subaru made very limited rwd only cars plus the extra length required due to the fact that the output is at the rear of the g/box not in the adds more length required and therefore more weight. So live yeah i was thinking about that but with an i6 or v6,8 etc there is only so low you can place the motor with a h6 i can place it on the same level as the axle line therefore eliminating a large amount of height to the centre of gravity
        • Burnall4
          • 145
          To make any AWD subaru into a RWD all you need is $100 US and 10 min....
          • GaryE30
            • 4791
            Care to elaborate? I doubt this is something that would be done cleanly/safely. But I will wait for an explanation before I make my decision.
            Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
            • Mclassy
              • 270
              Im waiting to hear this one too.
              • e30s52
                • Oct 2007
                • 5235
                this is going to be good
                www.gutenparts.com
                • BrewCity11
                  • Mar 2008
                  • 2335
                  It can and has been done. Drifters do it, for example. Not sure about the $100 though. If you leave everything else the same, you'll break alot of things.
                  Need stronger axles, diff, subframe, even tranny, etc, etc.
                  Cleanly+safely? Yes
                  Cheap+reliable? No
                  turk@gutenparts.com
                  • payney8
                    • Jun 2007
                    • 899
                    yeah exactly this has to be reliable guys.
                    • So Live
                      • 2512
                      I totally see your point with the H vs inline or V. Either way its very cool and i hope to see something come of this eventually.
                      So what kinda HP are you looking at with a good, affordable, reliable porsche motor?
                      -Chris
                      • payney8
                        • Jun 2007
                        • 899
                        thanks. Hopefully want around 400-500hp. The perfect balance between weight and power is 500hp to around 600kg. Was looking at a gt3 H-6 around 40-50k here in aus.
                        • el bob
                          • Feb 2006
                          • 348
                          I'm assuming you have already seen the http://www.dpcars.net/ website?
                          Have fun!
                          • BrewCity11
                            • Mar 2008
                            • 2335
                            Have fun!
                            Nice, thanks for posting that. I hadn't followed up on his build since January.
                            turk@gutenparts.com
                            • payney8
                              • Jun 2007
                              • 899
                              yeap thanks nice work though
