the never ending build
Haha i have a 16" Spal pusher in front of my m42 rad and an 80*C thermostat too. Mines the thinner one that still pushes 1900cfm of air. That and the 318is radiator fan switch gives me the same running a little over 1/4 all the time and never over half.
Good to know with the tape. Is it just adhesive tinfoil or a real heat resistant material? I have some tinfoil kinda stuff but i kinda dont want to melt my cover haha.-ChrisComment
im guessing that you have removed the a/c condenser then? i want to get a more powerful fan to replace the aux fan and if you guys are running a 16" pusher with a turbo setup i feel that i shouldnt have too much to worry about.Haha i have a 16" Spal pusher in front of my m42 rad and an 80*C thermostat too. Mines the thinner one that still pushes 1900cfm of air. That and the 318is radiator fan switch gives me the same running a little over 1/4 all the time and never over half.
i just need to find something worthy of replacing the aux fan because i can't figure out why the low speed won't turn on :(IG: deniso_nsi Leave me feedback here
I guess the resistor can get burnt out on the fans. I think you might be able to jumper out the resistor and have it just be on high speed all the time.
Yeah i have zero a/c stuff but i have a 2.75" thick intercooler in front of the fan. You should have enough room to mount the thin fan i bought in front of the a/c parts no problem.-ChrisComment
Awesome. Simply awesome.
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
i have the slim series, but if you dont have to squeeze it in between a rad. and fmic you can go pretty much any thickness. when i was na, i got a 14" from autozone to replace my aux. fan and it worked great.
oh, and the heat tape shit is kinda like a fiberglass material.
But, but, what about the Brocks?!-Erik
Originally posted by 87e30I just want to dance with some beeziesComment
Very cool build. I will check in on this from time to time. You have my attention!Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
much appreciated man.i have the slim series, but if you dont have to squeeze it in between a rad. and fmic you can go pretty much any thickness. when i was na, i got a 14" from autozone to replace my aux. fan and it worked great.
thank you.IG: deniso_nsi Leave me feedback here
subscribed. i want to turbo my s50 in the future, so it will be nice to see how this build turns out.
oh and i am using 75deg Tstat m20 rad, running a spal 12" puller fan running off the a/c fan relay on high speed at all times, and controlled via the A/C button inside the car. if i had a turbo motor i would probably run dual 12" puller fans...IG: @Baye30
FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
