Trial and error develops skill if you're smart enough to learn from the mistakes. Good luck with the rest of the panels; you're a bolder man than I with that 2000 grit in hand ha. Your tail light polishing technique is a winner.
JackBenny's 1991 318is Project
Quick question for you....how do you like the modified booster from Treehouse racing???? Is the performance of it fairly stock or is it stiffer??1989 325i|1992 325i|And completely obsessed|:woowoo:
sigpic BMW. The Ultimate Driving Machine.
The Build...Comment
Brake pedal feel is awfully subjective and I really haven't driven the car enough to give a good opinion on it. The Hawk pads in the rear are too thick and grab the rotor when hot. I think when I get that fixed, I'll have a better idea. To be quite honest, it's been so long since i drove the car stock, I'm not sure I remember what stock feels like! I like the feel so far but the pads haven't really been broken in. I would not purchase the booster from Treehouse though. I do like treehouse and their eyeball control arm mounts but I was disappointed in the booster. For what it costs, it should have come with a brand new booster and it sure didn't look like one.
And lest anyone thinks I've been slacking...
Another weekend, another panel...
-Josh
Check out my build thread...
http://www.r3vlimited.com/board/showthread.php?t=131055
Need parts? Support the community!
http://www.gutenparts.com
http://www.blunttech.comComment
Hmmm...that's a bummer about the booster. Rather disappointing considering it costs $400. Glad to know before I buy it though! Thanks!
And the paint is lookin good man! That gloss is lookin awesome!! :up:1989 325i|1992 325i|And completely obsessed|:woowoo:
The Build...Comment
If you need to thin your brake pads , flat rough concrete like a driveway or sidewalk works very well. Just rub them face down (obviously) til they are the thickness you want. I usually then give them a few passes over some 80 grit on a flat surface to give them a little finer finish before install.Comment
This is definitely an option but I want to take a closer look at the calipers and see if I was just a dumbass when I rebuilt them.If you need to thin your brake pads , flat rough concrete like a driveway or sidewalk works very well. Just rub them face down (obviously) til they are the thickness you want. I usually then give them a few passes over some 80 grit on a flat surface to give them a little finer finish before install.
I will try and get an update sometime this week. There is much dust in the garage from sanding. Sanding. I'm really beginning to hate sanding.-Josh
Jesus Christ.
That body work is coming out nice.
Jesus Christ.Comment
Sadly, the goal for completion was for this year's Vintage but you can see how badly I failed with that. For now it will be this summer as I want to start on the E21.
I have been doing some sanding and polishing in the meantime. I'll try and get some pictures up later today.-Josh
great work mate, enjoy the attention to detail. also as awful as it sounds its refreshing to see that even the best of us who build brilliant cars and have access to tools/others with greater knowledge etc still have issues. But its inspiring to see you press forward. I always seem to hit major snags and ask myself if others have this sh*t or is it just my luck haha
looking forward to seeing it all fall in to place :DComment
hai gais, I haz updates!
Life continues to impede progress on the e30. Coupled with the southern heat making the garage anywhere from 100 to 120 degrees F, I haven't been spending much time in the garage. Luckily, I got a portable A/C and while it isn't as cold as the inside of the house, it certainly makes the garage more comfortable to work in.
I continued to experiment with the pads, polishes and sanding. I upped the grit to 2500 and this helped with the scratches. I also got some Mequire's 105 and 205 compound and polish. The initial test was fairly successful.
The initial results were promising so I decided to work the entire driver's side with this technique.
Uploaded with ImageShack.us
I wanted more practice with the rotary buffer before I started though, so I took the sunroof panel off and brought it to the bench to work on. You might remember I initially sanded it with 1500 grit paper. As a result there was a great effort required to get the panel flat and remove the damage.
There are still flaws though. Admittedly I am looking at the surface with florescent light but any further sanding puts the clear coat thickness at risk so I'll have to learn to live with it.
I brought the panel into the house for protection and decided to implement the same procedure on the side of the car. I started on the rear quarter.
There is still a bit of waviness but given the circumstances, I'm satisfied with the flatness.
Blue tape was applied to the body line for protection and to keep things straight while sanding with 2500 grit.
Rear quarter completed.
Even though I had already polished the front fender, it wasn't flat enough compared to the rest of that side. That and my previous technique wasn't yielding the same results, so I started sanding the fender again with the same 2500 grit and polishing as on the rear quarter.
much better. Here the upper portion is polished and the lower portion is sanded.
and here is the panel finished. You can see the difference compared to a sanded panel just looking at the driver's door.
Sure do have a lot of pictures of the lights and workbench. Actually it was nice to have something standard to judge how I was doing.
The problem is when you work this close to the paint, you get to see and know and remember each individual flaw. When everything is polished up, it just makes them more obvious. Regardless, I am pleased with the results.
Now I needed to work the driver's door. This situation was unique because I had not touched the door at all, I started sanding with 2500 grit right off the bat. Note the cheap box fan used to generate near tornadic winds in my work area.
Lights continue to make their appearance...
and we are left with a polished driver's side of the car.
I still need to work the paint under the door protection strip but I'm pretty pleased. I'm going to try and get the roof finished before this weekend as well as Dad is coming to visit and we are going to repair the two screwups I made in the paint.
Til then....-Josh
