Progress is good
  • BlackSpeed66
    • Apr 2008
    • 624
    Progress is good
    H&R race w/ Bilstein Sports, Working on pressing out the subframe bushings today. Can't wait to get it on the road! Hoping to start off w/ some car-control clinics this spring. Sorry for the crappy-ish pics. I'll take much nicer ones once everything's buttoned up!
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '95 Jaguar XJR-6
    '02 Range Rover 4.6 HSE
    '98 Disco 1
  • Bimmerista
    • Nov 2005
    • 5425
    How funny...my H&R springs came with a cat as well. :D
    • TexasTerp
      • Jan 2009
      • 3541
      Looking good! Can't wait for more pics, how much are you dropping it with those H&R's?
      stephenbrody.com
      • BlackSpeed66
        • Apr 2008
        • 624
        I think the drop is about 1.5" or 1.6" with the front being lower. Gonna start off with all of the stock spring pads for starters and then adjust to taste. I do not want the car "slammed" but the 4x4 look doesn't work either. A little bit of rake is nice too.
        Here's the subframe ready to go back in. Not bad looking for 180k - I tried to clean the it up a little with some degreaser. It's riding on AKG subframe mounts and RTABs. The car's not my DD so I figured Poly would be alright.
        -Geno
        '87 325is (s52'd)
        '95 525iT
        '95 Jaguar XJR-6
        '98 Disco 1
        • sickbro91
          • Jan 2009
          • 95
          on the rear are you using those rubber spring pads?
          • BlackSpeed66
            • Apr 2008
            • 624
            Yes, I did use both spring pads in the back. Interested to see what the stance will look like.
            So close now.... had a marathon weekend in the garage with this thing. Got the subframe back in and bolted up, rear shocks installed, struts mounted up front, put the brakes back together, all wiring tucked away neatly, and got the exhaust back on (Stromung ). Tomorrow will be changing the oil and fixing the sending unit ground for my gauges.
            I'm sore as hell from rolling around on the garage floor. If 27 is this bad, what's 40 gonna be like??
            -Geno
            '87 325is (s52'd)
            '95 525iT
            '95 Jaguar XJR-6
            '98 Disco 1
            • Hallen
              • 1008
              Worse, trust me.
              I've done the exact same thing about a year ago:
              1987 E30 325is
              1999 E46 323i
              RIP 1994 E32 740iL
              oo=[][]=oo
