No start 87 325i
  • MagicFlux
    • Aug 2020
    • 2
    No start 87 325i
    Hey guys. I just got this car. It’s an ‘87 325i. It has no spark from what I can see. Cranks over, I can smell fuel when I do crank it. I tore apart the entire ignition system and checked everything that was replaced. Coil, plugs, wires, rotor, stator were all replaced less than 4K miles ago. The guy had two spare ECU’s in the trunk. Swapped both of them and it didnt fix the issue either. I’ve adjusted the throttle and idle cables, the idle control valve turns on when the key is turned. Fuel pump has been replaced and the relays all look new. No blown fuses. I also replaced the crank sensor after it had already been replaced. I have no idea what the issue is
  • Khoronzy
    • Jun 2016
    • 9
    Try cranking engine over at night. If the spark is grounding out u will see it when it is dark outside.
