Just another LS swap thread.....
  • salsa escobar
    • Feb 2021
    • 1
    I'm really bad about keeping up with my forum posts and updates. Hopefully I can keep this one updated lol. I present to you my E30 LS swap!
    Brake System:
    • Front: Wilwood 310mm rotors
    • Rear: Wilwood 295mm rotors
    • Front: Wilwood 6 piston dynapro calipers
    • Rear: Wilwood 4 piston calipers
    Drivetrain:
    • Stock 3.73 LSD
    • Sikky LS swap driveshaft
    Engine:
    • 5.3 LM7 from a 2002 Silverado
    • Rebuilt by B&R Speed Shop in Louisville
    • LS6 intake manifold
    • Griffin aluminum radiator
    • 2 electric fans
    • Sikky LS swap oil pan
    • Sikky LS swap mounts
    • ABS, heat, AC, cruise control delete
    • Sikky long tube headers 1 7/8”
    • LSX innovations alternator bracket
    • ICT coil pack bracket
    • MS3 Gold Box ecu
    Exterior:
    • Cliq Tuning e30 aero kit
    Fuel:
    Walbro 450
    Interior:
    • Pioneer head unit
    • Broken ebay steering wheel
    • Rep Bride seats
    • Takata harness for driver
    • Full interior soon to be deleted
    • Various stickers for go fast 😉
    Suspension / Wheel Setup:
    • Work Meister S1 16x8 et30 wrapped in Toyo R888R 225/45/R16
    • Sikky front control arm bushings “lollipops”
    • Ground Control complete coilover kit
    • Front koni adjustables bolted in existing housing
    • Rear koni adjustables
    • 1 Pair front camber plates
    • Set of Eibach springs
    • 4 Ground Control bump stops
    • Pair of rear upper shock mounts
    Steering System:
    • E36 325i steering rack to clear the oil pan
    • LS1 power steering pump
    Transmission:
    • T56 from 2002 Camaro SS
    • Spec stage 3 clutch with flywheel
    • Sikky trans mounts
    To be continued:
    • Chase Bays e30 brake booster delete kit needs installed
    • Wilwood pedal set needs installed
    • Braided lines for brake system
    • Gold Box ecu needs installed
    • Cliq Tuning aero kit needs fitted
    • Waiting until everything is done for a wrap as close to calypsorot as possible
    • Roll cage
    • Seat time 😊
    I will try to upload the pics in order from start of the swap to now.
    This is what the e30 looked like before the swap. A little Christmas spirit lol
    Pulling the old M20 out
    After pulling the m20, we painted the engine bay white. It got very dirty soon after lol. When everything is all said and done it'll get a respray
    Here's the clutch that I got, as well as getting the engine and trans together and dropped it in the car!
    I've never had nice suspension on any of my cars so I wanted to ball out on these lol
    The brakes were my favorite mod. I just love the way they look with the wheels!
    Here are a little bit of goodies that will go with the LS swap :)
    The swap currently sits here, front accessories are on, rad is mounted. The only difference is that the coil pack brackets are now different which will be shown after this picture
    The steering shaft was such a PITA to put in lol. Just like everything else on the swap.
  • zwill23
    • Jul 2015
    • 615
    The swap is looking clean so far! Good thing you've got an early model, you'll need the extra tire back there
