Funny Anecdote - Jag Related
  • wildstoats
    • Sep 2007
    • 896
    Saw this little story posted in the comments of a blog somewhere. Whether or not it is true it's still amusing.
    Sabotage on the assemble line is not confined to GM.
    In the early 70's, a mechanic friend was working on a Jaguar with a V-12, a distributor at each end of the block.
    The distributors not only had to be turned and set properly for their 6 cylinders but also timed to the other distributors 6 cylinders.
    He'd done enough of them to fix just about any timing related engine problem, except this one car. After trying every trick in the book, and he knew them all, he let his deep intuition guide him to pulling the valve cover to check out the cam shaft.
    Turns out the cam was put in backwards, a first in his long experience.
    The punch line is that when he cleaned the oil pan off before putting it back on, there inside the pan, a finger had written this in the yet to be dried oil pan paint:
    "Fu*k You Yank"
    Obviously a greeting for the export market customer of an obscenely expensive luxury car.
    Well he thought, good day to you too!
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    lies.
    • Danny
      • 14217
      Cool story bro.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        However, I do recall stories of UAW workers placing ballbearings in A-pillar channels. Take a turn, hear a metallic rolling noise.
        • equate975
          • Jun 2004
          • 3382
          When I was in auto school, my teacher said a student brought in a newer mustang because it had rear end noise. They pull the diff cover and started poking around. they found a crushed mountain dew can in place of a shim.
          Rollin' with a Geistkuchen
          • ThePotsy
            • Jul 2008
            • 210
            Someone told me about taking a defroster relay and putting it in place of the fuel pump relay.
            "Starts up, drives great for a while, and then it just dies and starts right back up!"
            "Our mother of blessed acceleration don't fail me now."
            • MikeDE
              • 1873
              Heard something like this also but it was a nut tied to a string hanging inside the rear fenderwell. When they found it after countless trips to the dealer and sending the car back to the factory for disassembly, the note on the inside of the panel read, "I bet it took you guys a long time to find this".
              -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
