what do i need to use tv screen for my laptop monitor
  • richardkeith97
    • 1693
    i've got a dell inspiron mini. i am trying to figure out what i need to use my tv screen as my monitor. do i need a vga to rca cable? can i use a vga to hdmi cable? thanks for the help in advance.
  • LBJefferies
    • Sep 2009
    • 1690
    I looked up the inputs for that notebook and your only option is vga so if they make a vga to hdmi then that is probably your best bet. Rca is old and shitty.
    • e34john
      • Apr 2006
      • 3599
      HDMI to HDMI, is yours the newer ones like the 10? If you have HDMI on the laptop and TV then thats the way to go. Cord is like 25 bucks at Target for a decent length.
      • LBJefferies
        • Sep 2009
        • 1690
        Originally posted by e34john
        HDMI to HDMI
        dell inspiron mini doesn't have an hdmi port... at least from what I read.
        • richardkeith97
          • 1693
          the newest one has an hdmi port. mine has the vga port. i just read somewhere that i need to make sure that my comp puts out a hdmi signal through the vga. i know the rca will work but i'm not sure on the hdmi
          • e34john
            • Apr 2006
            • 3599
            The one reviewed on CNET does, but the OP didn't give too much info on his setup.
            • richardkeith97
              • 1693
              mine doesn't have the hdmi port. just vga. just not sure if it puts out an hdmi signal.... or does that not matter?
              • LBJefferies
                • Sep 2009
                • 1690
                It probably matters. You could buy the cord and find out and then return it if it doesn't work. You might also need to turn on hdmi in the control panel.
                • unrlmth
                  • 467
                  What connectors are on both your TV and laptop? I like to use monoprice for cables, nice quality and very cheap prices.
                  Also some TVs have a VGA in. That would be the easiest, but we really need to know what you have on the back of your tv to make a solid recommendation.
                  1989 325i Alpineweiß II
                  • richardkeith97
                    • 1693
                    i do have a vga input on my tv. is their something in the settings that i need to do to make it work?
                    • Jand3rson
                      • 37587
                      If you DO end up running HDMI, do not let anyone tell you that you need an expensive one. Get the absolute cheapest one you can find.
                      • unrlmth
                        • 467
                        Just a VGA cable should do it. You might have to adjust the settings on your computer, but it will be the same as setting up any other screen.
                        +1 Unless you are going huge (35+ ft) distances it doesn't matter, and even then it isn't usually an issue.
                        • richardkeith97
                          • 1693
                          thanks for the help. i'm going to do the vga to vga first since its the easiest. then get a cheap vga to hdmi to see if that works.
                          • selturk
                            • Dec 2008
                            • 1197
                            S-video..
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              There is no need to go VGA-to-HDMI if you hook it up VGA-to-VGA. You won't get any better quality.
                              Also, unless you want to use the speakers on the laptop, you will also need an audio cable as VGA only does video. A 1/8" stereo jack-to-dual RCA's will be your best bet.
                              You can get both cables at www.monoprice.com
