Math question for engineers
  • b*saint
    • 3794
    Need someone to steer me in the right direction. How do I figure the power to move a 100 pound object from 0 to 2000 in/min in 1 second sitting on and attached to linear bearings with a friction coefficient of practically 0? What is my equation?
    Ma che cazzo state dicendo? :|
  • F34R
    sLaughter
    • 12376
    Does your wife weight 105?
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • b*saint
      • 3794
      No I making a cantilever machine for something
      • Hick
        • Sep 2005
        • 6451
        yeah?
        i just got done with my senior design project. Cantilever beam with an applied load reading strain through a DAQ. Theres a lot of little shit in there to make it read without bouncing.
        Originally posted by vlad
        • b*saint
          • 3794
          Yea I dont know the mechanical engineering end of it. I need a lot of help with it. The motion control is all me.
          • FredK
            • 14759
            Are you trying to size a motor?
            • b*saint
              • 3794
              Mostly LM guides and ball screw size.
              There is 3 to 5 different motors depending on what I go with for design, even tho it is only a 2D machine.
              • FredK
                • 14759
                Yeah, I was on a small team that designed a pump a few years back. I talked to the people at Automation Solutions, now i-automation.com, to ensure my motor and actuator selection made sense. They have a local office in Beverly.
                This book is helpful:
                http://ftp.cnchungary.com/Varsanyi_P...tor_Sizing.pdf
                • Conki
                  • 1254
                  wrong.
                  I'm drunk.
                  You need to look up a couple equations.
                  I'm going snowboarding.
                  Olololololol
                  1992 BMW 525iT Calypso
                  2011 Jeep Wrangler
                  • b*saint
                    • 3794
                    Fred I guess you're right. I also need to size motors.
                    A motor needs to overcome the static weight of the arm. So if the static weight it 45 kg I need to calculate how much torque to move it linearly via a ball screw in Nm.
                    • Conki
                      • 1254
                      Originally posted by conki
                      wrong.
                      I'm drunk.
                      Olololololol
                      :d
                      2011 Jeep Wrangler
                      • Philo
                        Ich esse kleine Kinder
                        • 3334
                        Force = (roughly) 38.42 N
                        M= 45.36kg
                        Vi=0
                        Vo-=.847m/s
                        t=1sec
                        a=.847m/s^2
                        F=Ma
                        38.42N = 45.36x.847
                        Are you sure that friction is 0? Practically 0 is not 0.
                        Is the direction of the force and object linear?
                        -tim
                        Originally posted by Jordan
                        I like the stance
                        • FredK
                          • 14759
                          2000 in/min = 33 in/s
                          33 in/s = .84 m/s
                          F = 38 N
                          P = Fv = 38N * .84 m/s = 32 W
                          edit: I think the key is to match load inertia with linear system inertia.
                          • b*saint
                            • 3794
                            M= 45.36kg
                            Vi=0
                            Vo-=.847m/s
                            t=1sec
                            a=.847m/s^2
                            F=Ma
                            38.42N = 45.36x.847
                            The friction is 0.0008. And yes.
                            • b*saint
                              • 3794
                              Ok so I did a weight check. My gantry is 130 pounds bare. Probably another 50 pounds once I attach the lm guides, linear stepper motor, hardstops, servovalve, and Z axis plate w/head.
