iphone 3gs experts.. just swapped LCD & Digitizer
  • Julien
    • 7471
    And now my lower loud speaker won't work. Dock connector is fine, so is mic. Phone just won't ring/play music/etc.
    I've tried cleaning the headphone port and it seems to recognize when they are plugged in (adjusts volume).
    The speaker worked post dropping the phone, but not after replacing the screen components. Any idea what to check or what could've happened?
    Thanks!
    Julien
    Build Threads:
  • matthugie
    • Mar 2004
    • 1810
    Tony B Chiu might be able to help. I'll ask him for you.
    88 325is - S52 powered
    Originally posted by King Arthur
    We'll not risk another frontal assault, that rabbit's dynamite!
    • CabbE30
      • Aug 2009
      • 2358
      Check '4' and '1'
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        There is a member that was opening an iPhone repair shop, maybe search for his thread and ask him?
        • Julien
          • 7471
          Originally posted by CabbE30
          Check '4' and '1'
          thanks, I'll try it.. didn't know there where two connectors for the lower PCB
          Build Threads:
          • Julien
            • 7471
            no dice.
            I did run the iphone with the lcd/etc unplugged for a bit (in my car).. could this have corrupted anything in the phone? I did a restore/software update on the phone already though.
            Build Threads:
            • equate975
              • Jun 2004
              • 3382
              Yeah that's me.
              #4 is the only connector that the sound goes through, #1 is for your antenna, either it's not plugged in or it's damaged. I would try swapping out the whole dock connector assembly (it's like $5 or so), If that doesn't work you have issues with your board. This is assuming the phone does not think headphones are plugged in all the time.
              Rollin' with a Geistkuchen
              • Julien
                • 7471
                Yeah I also think something happened with the dock connector assembly. Phone correctly recognizes when head phones are plugged in/etc.
                Build Threads:
