Computer harddrive problems
  • nickmp0wer
    • 1427
    So i came back from a trip and my computer was restarted for some reason an it was at one of the first screens that said not a valid system disk, eject and press enter. There wasnt a floppy but there was a office xp or something cd in it so i took that out and just restarted it. it came to the same screen and one of the harddrives made clicking noises for a couple minutes. what the hell gives? the computer is like a year old. it was the C: drive
  • Charlie
    kid tested, administrator approved
    • 6686
    Your HD is toast. If it's a retail box, call them and request a warranty replacement. If not, go purchase a new HD and stick XP on it. Stick the old HD in the freezer for a few hours (more like a day), and set it as slave. Boot up to the new drive with the OS installed and see if you can pull data off the old drive.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • Jordan
      • 12916
      What Charlie said. The freezer trick has worked for me many times, but you only get 5-10 minutes of use out of it before it dies again. Normally you can repeat the process if you need to.
      https://mtechniqueabs.com/
      • george graves
        • 20003
        Yep - I had never hard of the freezer thing and tried it on a whim. It's worked sever times - enough to get my important files off - Also shaking the drive gently work for me as well.
        Originally posted by Matt-B
        • nickmp0wer
          • 1427
          well i didnt really have much important stuff on it cause i just got it from my dad but i spent a long ass time setting it up the way i like it. the 2 harddrives in the computer are both the same, should i be worried about the other one? what harddrive should i get? the current ones are 200gb but maybe i will get one 400gb
          could it have been caused because i had the computer on the carpet?
          • george graves
            • 20003
            Sometimes drives just go bad - others have manufacturing prolbems - Like the IBM Deskstars.
            Carpet is fine. Try not to jar your computer when the drives are running. Every 6 months or so crack the case open and blow out the dust - computers on the floor seem to suck in more dust then others.
            • armeN
              • May 2005
              • 327
              i doubt you're gonna get anything off the drive. and it is warrenty convered. good luck
              I go wuaaaaaahh pssssshhhhh!!!!
